R50/53 Please help identify mystery leftover bolt
Old Sep 15, 2013 | 01:03 PM
mapetitevoiture's Avatar
mapetitevoiture
Ok, just because some of you might need a good laugh and others have done it before. It has been a long time since this happened to me! Just finished reassembling my r53; did supercharger oil change, put on new idler, belt tensioner, thermostat, water pump, crank sensor seal, hoses, 15% pulley, cooler plugs, trans oil changed again...and just about to put the bumper skin on when I see....a bolt. It's a 13mm head with a shoulder before the threads; and it's only one bolt but I can't seem to remember what it went to. It is a clean bolt, so I know it wasn't behind the s/c or anywhere there, as everything was covered in blacknastygoo. Anybody recognize this bolt? It is easier to ask than to start taking apart again. I was just bragging to myself; car started/ran great/didn't leak/didn't rattle. And then this bolt! Thanks for any help!
Attached Thumbnails Please help identify mystery leftover bolt-000mystery-bolt.jpg
Old Sep 15, 2013 | 02:53 PM
element's Avatar
element
looks like the bolt that holds on the black plastic air horn.. it goes onto the SC intake at the bottom of the SC. I just reinstalled that one on my clutch job
phil.
Old Sep 15, 2013 | 03:34 PM
mapetitevoiture
Phil, do you mean the one right on the front of the air horn/intake, where the black plastic has a slotted kind of hole and a bolt goes into the supercharger to hold the air horn to it? if so, nope it isn't that one-too big, and I know I put that one back. It's also too clean to be from there, as everything there was black. Any other thoughts?
Old Sep 15, 2013 | 03:52 PM
ACallahan's Avatar
ACallahan
Got all the thermostat housing screws in ? also seems to me there was a wire harness like bracket near the thermostat that may have had a bolt like that holding it down.
NYMADMINI
Dec 14, 2016 02:33 PM
buggyeye401
Oct 1, 2015 01:22 PM
buggyeye401
Sep 28, 2015 04:09 PM
EVMini
Sep 28, 2015 10:20 AM
daviday
Sep 25, 2015 01:31 AM
