R50/53 oil filter question ?
Old Apr 14, 2013 | 03:54 PM
hori's Avatar
hori
Was just looking at the napa gold oil filter for 06 mcs. The filter has hard plastic rings on end of filter but some different brand filters seem to have rubber rings on end of filter and felt on the other end from what I seen researching.
Any reason why they would not all be same?
Old Apr 14, 2013 | 04:00 PM
ZippyNH's Avatar
ZippyNH
Suggestion....
Buy the OEM or the MANN ( a euro brand thought to be one of 2 oem makers).
What happens is the O-Ring that goes around the can that holds the filter can be slightly undersized or over-sized, and leak/tear on install.
Not sure why one maker makes the filter different...
I think the NAPA gold is WIX.
Old Apr 14, 2013 | 04:13 PM
ZippyNH's Avatar
ZippyNH
http://www.waymotorworks.com/oem-min...r-r50-r53.html
You can also get multi-packs from some vendors,,,,a suggestion...get a kit the first time so you get the socket to get the filter off...
36mm Oil Filter Socket for all R50 R52 R53 MINI Cooper and Cooper S 2002-2006. This 36mm socket is extra short to allow easier access to the oil filter housing. It also uses a standard 3/8 drive ratchet for use. 6 point socket design to prevent rounding. Made from heavy duty steel, not cheap aluminum for lifetime of use.
http://www.waymotorworks.com/36mm-oi...er-socket.html for the socket
or the 1st change kit...
http://www.waymotorworks.com/oil-cha...3-r52-r50.html
Has a nice magnetic drain plug too!!
They have similar kits for gen2 cars!!
Old Apr 14, 2013 | 05:01 PM
bmwr606's Avatar
bmwr606
i would stick to mini oem filters only
my dealer sells them to me for $8.53 each including taxes if i buy 4 or more at a time
scott
Old Apr 14, 2013 | 05:33 PM
LittleJoe's Avatar
LittleJoe
I agree. OEM only for the oil filter.
Old Apr 14, 2013 | 06:12 PM
scf's Avatar
scf
I've had no issues with WIX.
Old Apr 15, 2013 | 06:37 AM
JP Money's Avatar
JP Money
Agreed. I use NAPA Gold with no issues.
Old Apr 15, 2013 | 07:26 AM
jimz68's Avatar
jimz68
NAPA Gold for me,too. No issues in 8+ years.
Jim
Old Apr 15, 2013 | 07:50 AM
hori's Avatar
hori
thanks folks, good to know
Old Apr 15, 2013 | 10:24 AM
Martin Brenneke's Avatar
Martin Brenneke
Also use Napa Gold- wix filters Since new 2005 JCW.
Kimolaoha
Jul 5, 2023 01:04 PM
devicemanager
Jun 17, 2016 06:18 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Lex2008
Aug 16, 2015 08:33 PM
Laura Redd Casler
Aug 15, 2015 09:32 PM
