R50/53 Coolant spewed out all at once!
Old Mar 9, 2013 | 05:07 AM
kerver's Avatar
kerver
I was driving along yesterday when I noticed my temp gauge starting to go up. I immediately pulled over and shut it off just as the red light started to blink. I opened the hood and of course there's no coolant at all. It was all over the top of the engine either. I called a tow truck and he said he saw on the road where it all spewed out. We looked underneath and it was all wet. It looked to me like it was more on the drivers side in the vicinity of the where the air filter sits. I didn't see any hoses off as it is really hard to see anything in there!
Is it possible I just blew a hose or could this be a whole other can of worms?
I just got my car back from a valve job 4 days ago....not sure if it would be related....
Where is the easiest place to start in your mind?
Thanks.
03 mini cooper base
Edit: I should note the car sat off for a good 45 mins while I got groceries and I drove less then 2 miles when it happened. So I wasn't doing any heavy driving.
Old Mar 9, 2013 | 07:09 AM
Braminator's Avatar
Braminator
Sounds like a hose did blow or was lose. The only way to know is to refill it after check all hoses and connections. Then idle it until it is warmed upto normal operating temperature. Then try bringing the RPM's up and watch for any leaks. Good luck
Old Mar 9, 2013 | 09:38 AM
kerver's Avatar
kerver
Hi Thanks for the advise.
I inspected all the hoses and found a large hose near the bottom of the radiator wasn't on right. The clamp that holds it on was about 5 inches down the hose not holding it securely. I managed to get it put back on right.
I refilled the system and did what you suggested. The coolant reservoir was bubbling. I let it run for maybe 10 minutes and then it over heated again so I of course shut it off. Nothing leaked out anywhere and the reservoir amount did not change....
I'm at a loss...would it be a bad thermostat or something?
Old Mar 9, 2013 | 09:51 AM
kerver's Avatar
kerver
I probably have to bleed the system....i'm reading into that now....
My mechanic said he had to pull the whole front end off to fix my cylinder head so i'm thinking that hose would have possibly had to been removed and never got put back on properly hence the snapring(?) makings its way 5 inches down the tube. I don't think that could have happened on its on since i couldn't slide it with my fingers. Gah:(
Old Mar 9, 2013 | 02:41 PM
kerver's Avatar
kerver
I wound up getting the car towed back to the mechanic to deal with since it was an error on his part and I don't want to make it worse. Hopefully he'll just have to bleed the system. Damn I wish I was a mechanic!! I do however understand the cooling system and it's components a lot better after this ordeal
Cheers!
Old Mar 9, 2013 | 04:23 PM
ZippyNH's Avatar
ZippyNH
Good move!
He can troubleshoot it....might be just a hose, or something related to the valve job.
I do know that even the just-a is a pain to bleed...my regular mechanic has a tool to help vacum bleed it....seems all mini's are a pain to deal with when the coolant system gets air in them...
Old Mar 10, 2013 | 06:15 AM
kerver's Avatar
kerver
Thanks Zippy
Old Mar 10, 2013 | 08:30 AM
e93m3's Avatar
e93m3
This happened to my sisters mini. The clamp holding the hose gave away. it was about a 15min fix but it sure was messy. GL let us know how you ended up
Old Mar 10, 2013 | 10:32 AM
kerver's Avatar
kerver
Got the car back today. He just had to bleed out the system and so far so good.....He took responsibility for not putting the clamp on the hose properly and fixed it with no fuss so that was at least nice.
Cheers!
Old Mar 10, 2013 | 10:35 AM
Braminator's Avatar
Braminator
Great news. Glad it all worked out. Good luck and motor on.
Old Mar 10, 2013 | 02:22 PM
e93m3's Avatar
e93m3
It's nice to hear that people still honor their work.
Old Mar 26, 2013 | 01:32 AM
suss1173's Avatar
suss1173
can anyone point me to a DIY for flushing and bleeding the coolent.
thanks
Old Mar 26, 2013 | 02:30 AM
buzzsaw's Avatar
buzzsaw
thanks
I googled your request and found this: https://www.northamericanmotoring.co...g-coolant.html
Old Mar 26, 2013 | 08:16 AM
suss1173's Avatar
suss1173
Buzzsaw, thanks for posting that link.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
vulkandino
Oct 31, 2015 08:29 PM
navybsn
Oct 4, 2015 03:27 PM
point665
Sep 29, 2015 12:41 PM
silence2-38554
Sep 28, 2015 12:19 PM
