R50/53 R56 JCW Shift knob work on an R53?
Old Jan 27, 2013 | 01:11 PM
tmscaf's Avatar
tmscaf
R56 JCW Shift **** work on an R53?
Trivial question in the grand scheme of upgrades, but the best I can tell from searching, the R56 JCW carbon fiber shift **** (with the JCW logo on it), will fit on an R53 without issue?
Old Jan 27, 2013 | 07:23 PM
MINIFatherFigure's Avatar
MINIFatherFigure
From: Perth West Australia in an industrial unit with my numerous cars.
Can you get to see one on the flesh? If the R53 is same as R50 it is a pull off; push on fit. You may be able to compare fitting area.
Old Jan 27, 2013 | 07:32 PM
Braminator's Avatar
Braminator
Sorry to say you will need an insert adapter.
Old Jan 27, 2013 | 07:49 PM
tmscaf's Avatar
tmscaf
Ha, now you have me curious...
Old Jan 27, 2013 | 08:04 PM
Braminator's Avatar
Braminator
They have lengthened the distance from the top of the lever to the locking groove, which means a pre-07 **** will not fit an 07 car properly, and vice-versa.
Old Jan 28, 2013 | 01:43 AM
MINIFatherFigure
If the lever is too long from the locking grove to the lever top it could always be buffed down with a file or petrol driven angle grinder.
Old Jan 28, 2013 | 09:21 AM
CravenSpeed's Avatar
CravenSpeed
Vendor
Here is what I know about it. Braminator is right, the distance from the clip to the fork in the shifter on the First and second Gen Mini models is different. The distances are roughly;
R53=35mm
R56=46mm
I am not sure how you could grind it down while retaining the clips at the bottom of the shifter.
Now, I am just trying to help so I hesitate end this like a salesman, but I have the adapters that Braminator is talking about. The catch is that they only fit our Adjustable Shifters. I can get a shifter set up for you that will fit your R53 whilst having the shift **** set up for the R56 JCW **** you are looking for. I know this adds to the cost and complexity a bit, but what you want to do can be done.
Old Feb 4, 2013 | 12:28 PM
Mib4840's Avatar
Mib4840
I bought the R56 JCW carbon shift **** for my R53. Whalen fabricated an adapter for me for $5 plus shipping. I have not put it on yet but am getting ready to. If any one knows how to make an adapter I am sure it is Whalen!
Old Feb 4, 2013 | 02:37 PM
tmscaf's Avatar
tmscaf
Looking forward to hearing back on how it fits
Old Feb 5, 2013 | 06:15 PM
Mib4840's Avatar
Mib4840
Okay, I just tried installing the adapter and shift ****. It did not snap into place like it should. The collar on the shifter shaft is blocking the **** from going down far enough. I don't want to modify the shaft or the **** so I'm going to contact Whalen and see what he can come up with to remedy the issue. The adapter fit perfect on the top of the shaft. I will keep you up dated.
Old Feb 7, 2013 | 10:39 AM
Mib4840's Avatar
Mib4840
Bad news, Doug Whalen was not able to help me with another adapter. My R53 to R56 conversion is a bust. Needless to say my JCW shift **** is going up for sale. Good luck with yours tmscaf.
dyeLucky
Sep 11, 2015 10:41 AM
1chaos52
Aug 24, 2015 01:28 PM
Accessory Products
Aug 11, 2015 12:19 PM
dyeLucky
Aug 7, 2015 07:10 AM
