R50/53 oem radio problem
Old Nov 20, 2012 | 09:18 AM
valefumi88's Avatar
valefumi88
oem radio problem
4 years ago i 've changed my radio.
but after these years i decided to go back to oem
and then i realised that something is missing from the back of the radio
the red circled spot where the antena cable goes
what do i do now ???
Old Nov 20, 2012 | 09:58 AM
Sc00terbum's Avatar
Sc00terbum
That is the female side of the OEM antenna connector. Your antenna cable should have the male side of that connector on it....unless someone butchered it. I bought a headpiece from Crutchfield last year and they gave me an adapter to the common style. It's just a short cable with a female end like your radio on one end and the common male plug on the other. Good luck!
Old Nov 20, 2012 | 10:24 AM
valefumi88's Avatar
valefumi88
my antenna cable is ok
the problem is that the radio is missing the circled part.
someone must have unscrew it
Old Nov 20, 2012 | 10:51 AM
rkw's Avatar
rkw
And who might that someone be?
I think they are standard connectors. There might be adapters available.
Old Nov 20, 2012 | 10:59 AM
Kahnfucious's Avatar
Kahnfucious
Don't know who that someone would be -- but I'll sell you my stock radio if you want to go back. CD player from a 2003..
PM me
Old Nov 20, 2012 | 11:05 AM
valefumi88's Avatar
valefumi88
maybe the guy that changed the radio..
i asked for adapters but they say its an oem part only and MINI doesnt sell it seperetely
as far as for you Kahnfucious, thanks,but i will try and fix this and if it cant be done i will go back to my aftermarket .
Old Nov 20, 2012 | 02:38 PM
ZippyNH's Avatar
ZippyNH
You think the installer moved the oem one on the radio to your aftermarket one....
Old Nov 20, 2012 | 05:27 PM
Eric_Rowland's Avatar
Eric_Rowland
+1 No other reason to remove; it's screwed in, so it's not like it just fell off.
Old Nov 21, 2012 | 12:36 AM
valefumi88's Avatar
valefumi88
totally agree with you that there is no reason to unscrew it.
checked my aftermarket unit and all the connections but nothing :(
blackie
Oct 2, 2015 07:41 PM
Zettinger
Aug 25, 2015 04:04 PM
FLYM1N1
Aug 16, 2015 01:15 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
veevsato
Aug 5, 2015 04:42 AM
