R50/53 Rough idle on start? R53
Old May 21, 2012 | 08:05 AM
Bradg33's Avatar
Bradg33
So my R53 has just recently started idling pretty rough on start, and even sputtering a little in the first few seconds after it starts. No problems actually getting it to start up, but it immediately sputters a little (RPMs drop to probably 500, then right back up). It then idles a little rough for a bit and ultimately smooths out. This is a new development. I recently took some steel wool to the #3 ignition coil (and checked the others). The spark plugs are new as of last October, but the coil is stock. Car has 72k on it, and a 15% WMM pulley. I plan to pull the intake house and see if the throttle body is dirty, in part because I feel like the throttle has been a little "sticky" lately (slower to respond). I wonder if the body has gotten dirty and is causing the flap/valve to stick. Any other ideas?
Old May 21, 2012 | 01:45 PM
BillyCuth's Avatar
BillyCuth
Common issue. Some suggest replacing the PCV valve can be a fix. Some suggest getting a new ECU flash from the dealer can do the trick. I've experienced this sporadically myself and cannot pinpoint it. Common wisdom would have you question the ignition system - and sometimes you can look at your coil and find a badly oxidated post (usually 3 or 4). Good luck. There are several threads dedicated to this issue.
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
Dsinkster
Aug 17, 2015 03:24 PM
Lt. Dan
Aug 10, 2015 12:46 PM
Lt. Dan
Aug 10, 2015 08:23 AM
