R50/53 Mishimoto Oil cooler. Any experience ?
Old May 7, 2012 | 08:54 PM
Dimoss's Avatar
Dimoss
Hi guys,
I`m changing my oem pulley to 16%. and thinking about reducing the oil temperature by installing oil cooler. I did some research on that online, and found a few options. I can get Setrab oil cooler fom minimania that will defiantly fit my MCS 2005 ($ 650), or get Mishimoto universal ($200) cooler from amazon. Big difference in price. Can anyone help me to decide?
Old May 7, 2012 | 09:43 PM
miles_miles7's Avatar
miles_miles7
just get the cheap one as long as its complete kit.
Old May 8, 2012 | 08:08 AM
quikmni's Avatar
quikmni
The key to a Mini Cooper oil cooler kit is the adapter plate used at the stock oil cooler location. I do not believe that the Mishimoto kit includes the correct adapter. I believe you can purchase the adapter plate from various vendors such as Sneed or Moss for around $100-$150.
The Sneed oil cooler kit is $500:
http://www.sneed4speed.com/sneed-spe...2002-2006-r53/
Old May 8, 2012 | 08:56 AM
Dimoss's Avatar
Dimoss
That`s right quikmni. The adapter is my concern. But even if I spend 150 for adapter and 200 for the cooler that`s $ 350 vs $ 500. And I heard Mishimoto makes very good cooler kits. What happens if I replace just a cooler ? And connect it to the original hook up?
Old May 8, 2012 | 11:17 AM
quikmni's Avatar
quikmni
The Mishimoto oil cooler looks very nice. The one universal kit I saw came with a 10-row cooler which I would think is more than needed for the Mini. If you go with that large of a cooler you might want to think about getting a thermostat valve to control the flow through the cooler.
If you go the Mishimoto route, you should check with the place you purchase an adapter plate from to see what AN fitting size is needed on the plate because you might need different size than included in the universal kit. You will also need to attach the cooler to the front of the car with brackets you make or straps through the radiator. Another thing to think about is the length of the universal oil lines and whether or not they can be cut to the proper length.
Another item to think about is if you are going to add a oil temperature gauge and where you are going to install the sensor. Some plates, such as madness, have holes for oil pressure and oil temperature sensors.
Old May 8, 2012 | 12:32 PM
Dimoss's Avatar
Dimoss
Thank you guys for the info. I guess I`m gonna go with the madness oil cooler. Btw, do I have to worry about oil pressure ?
Old May 8, 2012 | 04:24 PM
miles_miles7
modified oil cooler
If you can modify the cvt fluid cooler to engine oil cooler like I did then place and fitting wont be an issue.
Attached Thumbnails Mishimoto Oil cooler. Any experience ?-20120508_161852.jpg
Old May 8, 2012 | 05:25 PM
Cadenza's Avatar
Cadenza
Originally Posted by Dimoss
Hi guys,
Do you know what oil temp is (after full warm-up) since you installed the 16% pulley? Is it running too hot?
The reason I ask is motor oil has an optimum temp range where it flows best... around 90-105*C for normal driving. On the track, keep it below 130*C. If the external oil cooler lowers the oil operating temp too much, it's not good for the engine.
Old May 9, 2012 | 09:27 PM
GordonP66's Avatar
GordonP66
+1 on the thermostat. There was a thread on R53 oil temp data from way back that might be in the archives.
Old May 9, 2012 | 09:33 PM
Dimoss's Avatar
Dimoss
I`m not sure what temperature I`m running on right now, I haven`t install the oil temp gauge yet. But I think it`s a common sense, engine runs faster the temperature goes up, plus summer is coming.
Old Oct 1, 2013 | 10:28 PM
cavalera's Avatar
cavalera
oil temp definitely goes up if engine runs faster or longer...and the engine performance goes down...water methanol injectors directed to your intercooler helps feeding the engine with colder air and keeps the engine temp at minimal.
woodstudio
Mar 15, 2020 08:28 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
HaveATank
Aug 24, 2015 10:26 AM
danraabe
Aug 18, 2015 09:32 AM
stellaherself
Aug 13, 2015 03:48 PM
