R50/53 drain plug washer / crusher
Old Apr 29, 2012 | 06:08 PM
newninja's Avatar
newninja
is it needed for an '06 MCS? because i just did an oil change last night and it didnt have one but it looked like there was a rubber piece built into the plug. i have a 350z and i change the crusher every 3 oil changes or so. thanks
Old Apr 29, 2012 | 07:14 PM
ZippyNH's Avatar
ZippyNH
I generally reuse the stock plug....i did buy a couple extras online of the same oem plug with the rubber washer/rim built in....have never had an issue. If you were to reuse an aftermarket plug, useing a aluminum or maybe a copper crush washer might be a good idea.
Since it is pretty easy to gaul the head on the oem plug, having a spare onhand is is great idea...many folks have put one back on with a less than perfect head, only to have issues removing it later!!
Old Apr 29, 2012 | 07:17 PM
Blackbomber's Avatar
Blackbomber
Exactly what Zippy said, in my opinion. I keep a new spare in my toolbox top drawer, but have reused the one that came with my car for the last three changes, and it's fine.
Edit: Both OEM parts.
Old Apr 29, 2012 | 07:23 PM
newninja's Avatar
newninja
so the oem plug should have a copper or aluminum crusher. mine didnt have one, im gonna try to find them locally. thanks
Old Apr 29, 2012 | 07:26 PM
newninja's Avatar
newninja
btw where did you find them at ?
Old Apr 30, 2012 | 06:30 AM
buzzsaw's Avatar
buzzsaw
The oil plug size is M14x1.5. Most auto parts store sell them for less than $5.00. Last year I installed a magnetic plug purchased at Oreilly's for around $5. It does have a plastic washer which I replace at every oil change--which is probably an overkill. Good luck.
Old Apr 30, 2012 | 06:42 AM
Martin Brenneke's Avatar
Martin Brenneke
Get a Fumoto oil drain plug and you will never have to worry about your plug again. Also a lot cleaner and easier to drain the oil no mess.
Old Apr 30, 2012 | 07:41 AM
jimz68's Avatar
jimz68
To answer the original question, the OEM pan plug does NOT use a copper or aluminum crush washer. The rubber ring on the plug provides the "crush".
Jim
Old Apr 30, 2012 | 11:21 AM
newninja's Avatar
newninja
Thanks thats what i needed to know
Accessory Products
Sep 11, 2015 08:01 AM
Sep 11, 2015 08:00 AM
Sep 10, 2015 10:52 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Sep 2, 2015 09:05 AM
