R50/53 Terribly Annoying Rattle -- Ideas?
Old Apr 18, 2012 | 08:08 PM
jschnelk's Avatar
jschnelk
I am getting a terribly annoying rattle from the front of my MCS. The car is driving great, not loose at all, and on the highway, no rattle at all. I get it primarily at lower speeds and, obviously, as I am hitting a succession of small bumps. It sounds more like a loose cable of some kind maybe slapping dully against something as opposed to a metallic clank, but I am getting it from both sides. It seems to be louder in cold weather.
I had the car on a lift at my mechanic last week and he could not see anything. He said everything looked tight and good.
I do have the ALTA PSRS installed, but the control arms are welded on at the end, so I kind of doubt it is that, but maybe it is. I checked the front strut bushings and they look good too.
Anyone have any ideas? I'd really like to solve this mystery!
Old Apr 18, 2012 | 08:42 PM
RobMuntean's Avatar
RobMuntean
I know I am not a Gen 1 owner but man I have the same issue on my 11' MCS. I am wondering what the hell it could be only at lower speeds and small bumps I hear that little rattle. Good luck to you!
Old Apr 19, 2012 | 07:27 AM
OldGameFreaK's Avatar
OldGameFreaK
Check the sway bar end links and the sway bar bushings. Mine has bad bushings and makes a similar noise to what you are describing. Disconnect the rod ends and drive it over the bumps and see if it goes away.
Old Apr 19, 2012 | 10:12 AM
minimikeG's Avatar
minimikeG
check your motor mounts... you have a hydraulic mount check and see if it has leaked in the past or your lower is fatigued... I had all types of rattles at lower speeds in my 02 and replaced all three engine mounts... no she is quiet
Old Apr 22, 2012 | 08:36 PM
Bakerbrdz's Avatar
Bakerbrdz
Timing chain, 2000 dollar fix. I believe the clubman just had a recall
Old Apr 24, 2012 | 06:43 PM
jschnelk's Avatar
jschnelk
Checked all motor mounts, all look good. I doubt it is the timing chain, feels more like a chassis issue.
It seems if I go over bumps applying the brakes that the rattle is greatly diminished. Does this help narrow it down for anyone?
I keep thinking it is the PSRS bushings, but the mechanic insisted those were in nice and tight.
Thanks for everyone's continued input.
Old Apr 24, 2012 | 08:12 PM
jschnelk's Avatar
jschnelk
Old Game Freak -- Starting to think it is the front end links or the sway bar bushings. I'm hoping it is the former, as that is an easy fix. The latter would require front subframe removal (yikes). Will have mechanic check both on Thursday when I have it in for some other work. Will update then.
Thanks!
Old Apr 25, 2012 | 08:57 AM
Dirkdaddy's Avatar
Dirkdaddy
I had a bad catalytic converter. Was all broken up and eventually was gone, blew out.
See video
http://youtu.be/hXYhDKS8N8c
ToyCar
Nov 19, 2023 05:20 AM
BernieCoop
Sep 10, 2021 03:15 AM
embiggenedmini
Oct 15, 2015 12:36 PM
rob&JCW
Sep 10, 2015 12:06 PM
Sep 8, 2015 11:37 AM
