R50/53 Clutch Switch(s) on R53?
It's either the switch there, or the one in this attachment. After a little more searching, I think I've found the answer. It looks like MINIs made before 7/2001 used a switch in the location in my first post. MINIs made after that used the one in this post...I think...
If you press in the pedal you will hear a click. This switch is, as previously stated, for when you start the car and if you have cruise control - it turns off the cruise control just like the brake pedal.
Exactly. My reason for asking is my MINI is a conversion from a CVT automatic and doesn't currently have the switch. I've been looking into wiring it in - start inhibiting would be good in case anyone ever borrows the car.
Was just double-checking which switch it actually is, since both are listed in the parts listings, but only the one on the master cylinder shows up on the wiring diagram. As far as I can tell, the one on the master cylinder is the one.
You will need more than a switch to make it work. Perhaps a new ECU or at minimum a reprogram unless the installer just shorted out wires somewhere to mimic the switch forever.
Best to just leave it, cars were like that for years until the lawyers go into car making.
I'm guessing your coding overrides the need for the switch, so it would have to be re-flashed too?
Unless you're bypassing the need for the switch in some other way...
Looks like the clutch switch on my '03 is going bad. I have to have the clutch all the way against the floor before the car will turn over. Sometimes I have to push it a couple times before it will let the car start.
Is there a way to do away with the switch? There are 4 wires for the switch. Will pulling the connector out of the switch let you start the car? Or can you short two of the wires?
TIA
Alan
TIA
Alan
You might be able to, but you would need to verify that the Hall sensor in the clutch switch is closing the circuit and it is normally open. It would be pins 1 and 4 for the immobiliser. I've attached the wiring diagram and arrangement of the pins.
If you completely remove the switch, you might also mess up cruise control functionality.
A new switch is only about $40 - I would just go that route.
Great Info! And thanks for the quick reply. I'm off for a track weekend in about an hour and want to have a plan B in case it fails on me. So, I'll throw some wire and the VOM in the track box.
If it lasts the weekend I'll spend the $40 and just replace it.
Thanks again,
Alan
Thanks again,
Alan
Clutch switch hall sensor
whats next? Any feedback welcome! After a week, I miss the driving. Ps: 128k miles so I suspect the answer will be pull the starter. :/
Are you sure the battery is good? Maybe was just by chance it started after you held a magnet near the clutch.
When my starter went bad, the symptom was it wouldn't always engage the flywheel on really cold days. I'd get a kind of whirring sound until the starter gear would finally move enough to lock in with the flywheel gear. If you're not hearing anything at all from the starter, might be the starter solenoid, or even the wiring for the clutch switch.
BTW, for anyone whoever runs by this thread in the future, I did end up adding all of the wiring in for the clutch switch many years ago which allowed me to get cruise control back after the CVT to 6-speed conversion. Works fine to do this day!
Your feedback regarding the sound has given me enough evidence I need. Thank you.
Hopefully the starter fixes it for you. Sometimes just cleaning the carbon and clutch dust out of the starter will give it a second life. I did that about 5 years ago on mine and it's been fine since.
andrewjg1994
Jan 29, 2021 07:45 PM
R50/53 Switching out stock seats
MiniSBruce
Aug 12, 2015 10:00 AM
