R50/53 TO bearing noise. How serious?
Old Jan 3, 2012 | 06:34 PM
abadgti's Avatar
abadgti
TO bearing makes noise only when clutch is out and in neutral. If I let the clutch out slowly it doesn't make any noise. Still shifts perfect and has plenty of power. Previous owner told me the clutch and everything associated with it was replaced. Should this be addresses immediately? I have read that this is a common problem with Minis. Thanks for your help.
Old Jan 4, 2012 | 07:11 PM
valvashon's Avatar
valvashon
The throwout bearing in our R50 went from quiet to really noisy to pieces in four hours. Sounds like yours is not as serious, but I wouldn't go anywhere without a phone.
Val
Old Jan 4, 2012 | 07:22 PM
SniperDetailing's Avatar
SniperDetailing
it could just be flywheel chatter. do you know if the previous owner replaced the clutch/flywheel with a dual mass or a single mass? I know when I had a single mass flywheel in my Jetta it ratted pretty bad when in neutral and clutch out, but it wasn't the throwout bearing at all and was nothing to worry about.
Old Jan 6, 2012 | 10:43 AM
Baker555's Avatar
Baker555
What exactly does the noise sound like? Is the clutch pedal smooth or kind of rough/squeaky?
Old Jan 6, 2012 | 10:45 AM
abadgti's Avatar
abadgti
Clutch pedal is smooth and it shifts smooth. Sound like a rattle with the clutch out and in neutral.
Old Jan 7, 2012 | 09:43 AM
abadgti's Avatar
abadgti
Clutch pedal is smooth and it shifts smooth. Just sounds like a faint rattle sometimes with the clutch out and in neutral.
Old Jun 16, 2012 | 07:56 AM
Wetmini's Avatar
Wetmini
I have the same noise under the same conditions.....nothing has changed for 12,000 miles.
Old Jun 17, 2012 | 07:38 AM
clay44's Avatar
clay44
There's a thread out there explaining this issue if i find the link i'll post it. I've had the same noise for a few thousand miles. My fix is to let off the clutch slower than normal noise goes away and i get to ignore the promblem a bit longer. From what i've heard it's not a big problem more embarassing than anything else.
Old Jun 17, 2012 | 07:44 AM
xsmini's Avatar
xsmini
Dual mass flywheel noise, it's normal withnthese cars. Mine has been noisy for well over 200,000 miles. It's fine.
Nik
Old Jun 17, 2012 | 07:47 AM
clay44's Avatar
clay44
Doc Pain
Mar 10, 2021 04:50 AM
vulkandino
Oct 31, 2015 08:29 PM
Chefben63075
Oct 1, 2015 12:04 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
Nicefeet
Sep 24, 2015 06:53 PM
