R50/53 How much does the dealer charge to install the toggles and m
Old Feb 17, 2004 | 04:24 PM
resmini's Avatar
resmini
I saw somewhere that the new toggle rack was $75. Just wondering what the total charge would be.
R.E.
Old Feb 17, 2004 | 04:37 PM
GoMiniGo's Avatar
GoMiniGo
Yes, $75 for the part and 1/2 hour labor which in my case was $43.00.
Plus tax of course.
GMG
Old Feb 17, 2004 | 08:11 PM
Thrilhouse's Avatar
Thrilhouse
That's not too bad...maybe I should get that done...and get the front driving lights installed so i can have a full bank of toggles.
Old Feb 17, 2004 | 08:17 PM
early_apex
do you mean front fogs? the driving lights work off a button to the left of the steering wheel.
Old Feb 17, 2004 | 09:15 PM
GoMiniGo's Avatar
GoMiniGo
Not the driving lights (the accessory lights mounted to the grill) but the front fog lights mounted behind the bottom bumper.
The six toggles are in the middle of the center console. All MINI's have at least four, some had five with the addition of the front fogs. Now you can finally get the sixth position filled with the addition of the rear fog lights.
GMG
Old Feb 18, 2004 | 05:49 AM
shift-knob's Avatar
shift-knob
I have been out of the loop for a while, I see that Mini has released the 6 toggle switch unit. My question is this just a switch that can operate anyting ( PIAA lights)? secondly do the foglights on the Mini shut off when the highbeams are turned on-my thinking is if there is enough juice in the lines to operate the driving lights off the fog light circut I could use it to power the PIAA's and fogs.
Old Feb 18, 2004 | 06:00 AM
jack07734's Avatar
jack07734
Towne MINI in Buffalo, NY charged me $45.00 to have that done.
Jack
Old Feb 18, 2004 | 09:31 AM
gt6's Avatar
gt6
The switch is tied to the existing plug and wiring harness in the car already. The rear fogs and wiring are actually in the car from the factory, they just didnt' supply the toggle to turn them on and off. If you want to use the switch for another use such as driving lights you would need to redo the harness and/or plug. And yes, the fogs do turn off when the high beams are turned on. Most states (probably all) have a law restricting the numer of lights that can be on at a given time. Some states even require you to cover any extra lights (i.e. driving lights) while on the road.
Old Feb 18, 2004 | 09:32 AM
gt6's Avatar
gt6
You also need either version 35 or 36 software to be able to activate the rear fog light.
Old Feb 18, 2004 | 10:04 AM
q-man's Avatar
q-man
The rear fogs are now a factory option in the US ($100). They weren't when I first ordered in early January and I had arranged for the dealer to do it after the car gets here. Before my MINI entered production however, I noticed it had appeared as a factory option and had the dealer add it my spec., saving me a few $$s. Seems a bit of a stretch to charge $100 for substituting a switch panel with 6 switches for one that has 5, but from a safety standpoint I guess its worth it.
Old Feb 18, 2004 | 10:25 AM
mini-rolls's Avatar
mini-rolls
I got my panel from Classic MINI and installed my self. Need to remove 8 screws, to get to the panel and then 2 screws for panel plus a cannon plug. Took 1/2 hour at the most. Stopped by the dealer and they activiated the rear fog lights for $0, and my rear fog light mod was installed at the time and had no issues. Rear lights works as advertised. Brake on; rear fog off - both upper and lower lights on, brake off; rear fog off - all lights off, lights on; rear fog on - upper lights bright, low lights dim, with the rear fog on and applying the brake no affect upper light, lower light dim.
Cost of New Panel - $60.00 / Installation and Activiation of new Panel - $0.00
Brake Light Modification Kit - $14.00
Having all the lights in back of my MINI working = Priceless
Dave
MINI-Rolls
Old Feb 18, 2004 | 10:34 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
>>... they activiated the rear fog lights for $0
Wow, that's sweet! Which MINI dealer is that?
As MINI-rolls mentioned, the installation of the penal is relatively easy. I had my alarm and rear fog lights activated for $45, which is 1/2 hr of labor. I think that's reasonable!
Old Feb 18, 2004 | 10:40 AM
mini-rolls's Avatar
mini-rolls
Northwest MINI - I bought my car from them and they said they will do any programming for free since I bought it from them.
Pretty sweet!!! I like the service I get from them.
Dave
MINI-Rolls
adrchn
Aug 13, 2019 02:11 AM
surfblue
Oct 24, 2018 01:20 AM
squawSkiBum
Oct 2, 2015 09:21 AM
