R50/53 aeroforce interceptor or scangauge
Old Oct 1, 2011 | 10:48 PM
MiniSuperDuke's Avatar
MiniSuperDuke
they seem comparable in function... scangauge is a bit less expensive while the aeroforce has a cleaner look. anybody have the aeroforce unit and if so does it meet your expectations
Old Oct 2, 2011 | 04:56 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
FWIW I purchased a Scanguage II used, here in the marketplaces few years ago. Last month at WOT, the screen would go blank.
I emailed Scangauge and received a prompt reply to send it in for a "free program upgrade and servicing." I sent it in w/o the cable since it's routed behind my dashboard.
They charged me $0.00 and it was back in my mailbox two weeks later WITH a new OBDII cable !
Old Oct 2, 2011 | 02:13 PM
Gil-galad's Avatar
Gil-galad
I have dual AeroForce Interceptor gauges, and I can say that they've actually exceeded my expectations. I love the frequency of data update (which is configurable and blows away the Scangauge II) -- I have mine set on 10 Hz (originally 5 Hz) which is not the fastest setting. I'm also happy to report that in my '11 MCS I actually get MORE functionality than is listed in the Aeroforce online manual (e.g., the manual doesn't list Boost Pressure as an available setting for the MINI, but it does, in fact, display).
I'm sure the performance in a 1st Gen install would be comparable.
Here's a little clip I assembled to document my install:
Old Oct 3, 2011 | 07:12 AM
Suzanne's Chili Red S's Avatar
Like the looks of the AeroForce set up! The only concern I would have is the size of the text (not the numbers) - looks like that could be an issue for older eyes to read, but perhaps the white lettering on the dark background would improve that. Otherwise, VERY nice!
Old Oct 3, 2011 | 09:00 AM
Gil-galad's Avatar
Gil-galad
Thanks. I usually leave the same function in the upper three read-outs (voltage, coolant temp, and boost pressure, respectively) so I don't really have to read the function labels to know what I'm seeing. The bottom read-out (lower half of the bottom gauge) I cycle between MAF, Intake Air Temp, A/F Ratio, and Throttle Pct depending on my mood -- since the values and update rates for these functions are different, again, you don't actually need to read the label to know what's there. FWIW, my 54 years young eyes have no problem with the labels even without my glasses on.
I get a bit of reflection off the gauge faces through the driver's side window during bright, overcast sky conditions which is the only time the contrast is a bit reduced, but even then they are clearly readable. If this was a bother, one could easily relocate the gauges to the right-hand side of the steering column to mitigate it. It's not worth it to me; I much prefer the look of the gauges to the left of the column.
Old Oct 3, 2011 | 03:31 PM
MiniSuperDuke
Gil-galad, install looks reallygood.. where did you get a wire for power, and did you just strip back the insulation a bit and wrap power wire for interceptor gauge around it? Also, in regard to the other wire that goes to port where did you route it?
Old Oct 4, 2011 | 05:55 AM
Gil-galad's Avatar
Gil-galad
Originally Posted by MiniSuperDuke
Gil-galad, install looks really good.. where did you get a wire for power, and did you just strip back the insulation a bit and wrap power wire for interceptor gauge around it? Also, in regard to the other wire that goes to port where did you route it?
Well, this is a 1st Gen thread and I don't want it to stray too far off-topic, but I'll share that I tapped into the 12v switched power feeding the front 12v accessory socket (aka, cig lighter). Didn't even need to remove the center console; just removed 3 screws and lifted it up high enough to access the connector on the back of the socket (I think it's a bit more involved on an R50/R53). I used a T-tap to connect to the wire.
The data cable just feeds down along the steering column and down to the left of the clutch pedal mechanism to the data port. I coiled the extra length of cable behind the knee bolster. Neat, tidy, and functional.
Old Oct 4, 2011 | 07:49 AM
Minidrivr's Avatar
Minidrivr
Love my Aeroforce Interceptor. It replaced a Scangauge II. The Aeroforce updates much quicker and looks nicer when mounted in a gauge pod compared to the rectangle SGII mounted near the tach. Also like the configurable LEDs. I have mine set when water temp gets to a certain number. They can be used as shift lights as well.
The person who recommended the Aeroforce to me had a mechanical boost gauge along side the Aeroforce. The Aeroforce updated just as fast as the mechanical boost gauge, if not faster. Literally in milliseconds. The SGII has about a 2 second delay and out of the box doesn't display boost without programming. The Aeroforce has an altimeter so it corrects the boost reading. The SGII doesn't have this function.
The display on the SGII is better. I had a lot of glare with the Aeroforce when mounted on the right side of the tach. I had to move it to the left side to keep from seeing the rear sunroof reflection. That's the only downside for me. It's clearly visible in direct sunlight, changes color slightly just like the display on the tach when sun hits it. Once I mounted it on the left of the tach, glare was no longer an issue.
I powered it from the cig lighter socket.
Old Oct 4, 2011 | 09:31 AM
Neitherfanboy's Avatar
Neitherfanboy
Anybody else bothered that you can't change the display on the Aeroforce to match the color of the dash lights? I know its A/R of me, but I am just annoyed when my accessory lights do not match the dash!
Old Oct 4, 2011 | 09:35 AM
Gil-galad's Avatar
Gil-galad
You CAN order several different colors of display...
http://aeroforcetech.com/images.html
...but you are correct that none of them are an exact match for the amber MINI lighting. I've seen the red displays in other MINI applications; I prefer the black/white.
I can't speak for how close of a color match you can get with a Scangauge.
Old Oct 4, 2011 | 10:20 AM
Minidrivr's Avatar
Minidrivr
I chose the red display Aeroforce. It's not a match to the the MINI's dash but looks ok to me. I also use a V1 remote display in a 52mm gauge pod with an orange display. It matches exactly. So color and glare were the two con's of the Aeroforce for me. But the features outweighted those issues. SGII gives you 4 fields at once while the Aeroforce gives you only 2. You can set the Aeroforce to cycle through different fields automatically though.
Edit: This is what the red display looks like. This was before I moved the gauge to the left side of the tach.
Old Oct 4, 2011 | 10:28 AM
angrydave's Avatar
angrydave
I'm thinking Scangauge is red, blue, or green, but it's been a while since I looked at the options. Mine is set to red, I think at about 75% brightness, so it's not too far off from the orange.
Old Oct 7, 2011 | 09:24 AM
zpeedyz's Avatar
zpeedyz
I'm quite interested in getting 1, if not 2, Aeroforce Interceptor gauges, but I wonder how many settings it reads from the OBD II port are calculated as opposed to real? I know this isn't a drawback of the aeroforce gauge itself, especially since they offer additional external sensors, but it would be a deciding factor for me.
On the accessport, it shows EGT and IAT and the like, but are these values calculated, or real? Same goes with lbs of boost.
Thanks!
Old Oct 7, 2011 | 09:38 AM
Minidrivr's Avatar
Minidrivr
Thanks!
Not sure. Aeroforce has a forum where I'm sure you would get an answer. They're very responsive to comments, questions, etc.
Old Oct 7, 2011 | 12:04 PM
Nick Danger's Avatar
Nick Danger
If you have a smartphone, why not the PLX Kiwi? Using the Torque App, You can run anywhere from one to six gauges per screen. I have engine temp and GPS speed on two screens, then on another I have a collection of six gauges displaying stuff, including boost. I have yet to configure the four other screens. It is fully customizable and reads the data directly from your OBDII port. Moving between screens is a quick swipe. Torque will also allow you to read and clear fault codes.
I always have my phone, so I simply snap it into my cradle, click on the Kiwi, launch torque and it communicates via Bluetooth, so no wires to hide or trip over.
I believe the Kiwi with shipping and the purchase of the Torque app, I am into the setup maybe $100. I'll take the Pepsi Challenge against the Scanngauge or Aeroforce all day long.
Old Oct 7, 2011 | 01:30 PM
jdub2k5's Avatar
jdub2k5
does the aeroforce dual gauge setup come with pods?
Old Oct 7, 2011 | 09:54 PM
Minidrivr's Avatar
Minidrivr
They don't come with the pods.
Old Oct 10, 2011 | 06:41 AM
MiniSuperDuke
I do always have my smartphone and regularly use it to stream music via bluetooth.
Thus, it would be logical to try kiwi...gonna do a bit of reading on it and see. With a good mount it can be tucked down low or higher and even used to video..
Old Dec 5, 2011 | 12:07 PM
binitraveller's Avatar
binitraveller
just started looking into these. for iPhone, are you using the KIWI Wifi or KIWI bluetooth? I do use bluetooth already for my phone functions/handsfree, so maybe better to use wifi link? pretty cool that can get multiple gauges displayed.
also interested what iPhone mounts you find seem to work best when using as a gauge display?
Old Dec 5, 2011 | 01:37 PM
Nick Danger
I run KIWI Bluetooth through my Android phone.
I have the Panavise universal mount number 15523. They also have an i-specific mount for a lot more money. http://panavise.com/index.html?pageI...ECTIONSword=ww
Old Oct 15, 2016 | 09:03 PM
odieman23's Avatar
odieman23
List of data display
Anyone that has the Aeroforce Gauges...could you list all the data that they display for R56 MINI Coopers?...Please
shorenetworks
Nov 4, 2019 06:18 PM
sunman
Oct 24, 2018 05:25 PM
Chasp
Sep 4, 2015 09:31 AM
D-MAN
Feb 19, 2011 01:22 AM
jayk
Jun 7, 2008 09:05 AM
