R50/53 Just a heads up for those that do routine maintenance themselves.
Old Sep 15, 2011 | 01:09 PM
ieandro's Avatar
ieandro
Hey guys,
I ordered plugs, wires, ignition coil from Amazon the other day and went about installing it and came up with an issue with the coil pack.
The stock coil pack has 4 (10mm) hex bolts, each surrounded by a metal sleeve and two rubber bushings. When removing, the bushings themselves come off, but not the sleeve.
My issue is with the new coil pack from a company called OEM (Original Engine Management - not to be confused with Original Equipment Manufacturer). The new coil packs bolt holes do not allow the sleeve to be inserted and try as i might, could not remove the bolts from the sleeves themselves without thinking of ruining something.
No big deal, really. I could get new bolts from home depot, but i'm at an age where when I buy things to plug and play, I don't want to spend extra time modifying things to play.
So just a heads up is all if you come across this type of coil pack.
Quick question though for those who maintain and not upgrade .. which coil pack was a direct swap? Original mini is quite expensive.
Old Sep 15, 2011 | 01:37 PM
Spraypaint's Avatar
Spraypaint
How much is the stock replacement from mini?
You can do the MSD upgrade for $120, and it comes with bolts (for your pleasure):
http://new.minimania.com/web/Item/NME3021/InvDetail.cfm
Old Sep 15, 2011 | 01:42 PM
ieandro's Avatar
ieandro
I could, but everything is stock and that's the way i like it so the addition of a coil that could pump 40K volts through stock 7mm wires would be a moot point.
Plus the coil I got was $40. I just need to find one with holes larger that are actually OEM fit.
Old Sep 15, 2011 | 01:44 PM
Spraypaint's Avatar
Spraypaint
Ah, that is a good bit cheaper.
Autopartswarehouse.com has always treated me well when it comes to cheap stock replacements (as you know, not everything needs to be upgraded). Check there?
Old Sep 15, 2011 | 01:48 PM
ieandro's Avatar
ieandro
Thanks!
I'll be checking that out.
Old Sep 15, 2011 | 02:01 PM
jaqattack02's Avatar
jaqattack02
Have you tried rockauto.com? I love that place. I haven't gotten anything for the Mini from there yet, but I've gotten stuff for a number of other cars. Fast shipping and good parts. They have coils from 7 different manufacturers on the site. Give it a look, one will probably fit the bill for you.
Old Sep 15, 2011 | 02:06 PM
ieandro's Avatar
ieandro
I was going to use rock auto, but i have Amazon Prime so the shipping was free.
Anyway, I checked out Mini of South Atlanta to see the exploded diagram of the coil and its parts and found no type of sleeve to be had in the diagram. Its called a collar screw http://parts.miniofsouthatlanta.com/...rchString=coil, but the picture shows no sleeve whatsoever.
Maybe my sleeve from the pack came off? Still doesn't explain why I couldn't get it off. I may just have to go to Home Depot.
Old Sep 15, 2011 | 02:16 PM
JCWSLAYER's Avatar
JCWSLAYER
Purchased MSD coil and wires and had same issue got screws online couldnt find size I needed at Home Depot. Entertained the idea of drilling holes out so that the OEM ones would fit.
Old Sep 15, 2011 | 03:09 PM
ieandro's Avatar
ieandro
JCW .. i have issues with the metric system at Home Depot too. They never seem to have that right size. What size did you ened up getting online?
Old Sep 16, 2011 | 07:11 PM
jhziiik2's Avatar
jhziiik2
http://www.waymotorworks.com/screami...-coil-pak.html
COOPT UP
Sep 11, 2015 04:59 AM
ronn
Sep 9, 2015 07:12 PM
Manny_cooper
Sep 4, 2015 08:28 AM
Sep 3, 2015 10:45 AM
Sep 2, 2015 09:05 AM
