R50/53 instrument light dimming switch
Old Dec 3, 2003 | 02:03 AM
acotam's Avatar
acotam
anyone tried to actually use this switch? i have played with it many times under different lighting and cannot seem to see any difference.........
Old Dec 3, 2003 | 02:36 AM
jsun's Avatar
jsun
Go outside, turn on your ignition, sit in the dark (like how it probably is at 5am...unless you live on Antarctica), and then press the switch several times. You ought to see the orange instrument lights dim or brighten depending on which direction the rheostat is headed...it gets brighter until its limit then starts getting dimmer.
If this doesn't happen for you, then you may have a broken switch I suppose; but I'm betting it's just not been dark enough and/or you haven't pushed it enough. IMO this is one of the silliest controls in the MINI as relatively few people I've met have been able to figure it out at first. Once again, style trumps utility... Good luck!
Old Dec 3, 2003 | 05:33 AM
CooperBeagle's Avatar
CooperBeagle
Gee... I thought the idea was to tap the switch with the music you're playing for a disco effect.
God speed.
Old Dec 3, 2003 | 05:54 AM
countrym's Avatar
countrym
The way I understand it, tapping the switch repeatedly reduces the brightness incrementally. Holding it down increases the brightness. If it's already at max brightness, holding down the switch won't do anything.
Old Dec 3, 2003 | 05:55 AM
MG-BGT's Avatar
MG-BGT
I had some trouble with it at first. The switch is supposed to work as such:
press and hold will increase brightness up to max. As it is increasing, release when you have the brightness you want.
To decrease: repeatedly tap the button to decrease until you get to min.
My problem was that my taps were too long. Try real short taps, repeatedly, and the display should dim substantially. Then hold until it is really bright.
M.
Old Dec 3, 2003 | 05:57 AM
MGCMAN's Avatar
MGCMAN
My dimmer works very well, thank you. It takes my interior lights from a stealth fighter dull glow up to "It's the Great Pumpkin" luminiscence if I want to fry my retinas and freak out the kids.
Old Dec 3, 2003 | 07:50 AM
apexer's Avatar
apexer
IMO the highest brightness level is not high enough for daylite viewing. On a bright sunny day I can hardly read the digital speedometer/tempature section on the tach. This is especially true if I'm wearing sun glasses. At night the adjustments to the brightness level are adaquate.
Old Dec 3, 2003 | 08:18 AM
Phobol's Avatar
Phobol
If you turn off your head lights then all the digital readouts will get a whole lot brighter, so you can see them in the sun.
Old Dec 3, 2003 | 08:31 AM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Wearing polarizing sunglasses can sometimes completely obliterate readings for any of the LCD readouts in the car (odo, trip computer, clock, radio, Nav). LCD readouts work by utilizing polarizing filters, and depending on the 'orientation' of the polarizing filters on the glasses relative to the displays it will have no effec to completely blacking them out.
To see if you have polarizing sunglasses, or to just see the effect, hold the lens over any of the displays while it is on, and rotate the lens. You will find two spots (180 degrees apart) where the display viewed through the lens will go completely black.
Old Dec 3, 2003 | 08:49 AM
10851CS's Avatar
10851CS
You'r right. I just got new glasses and with the magnetic clip on dark lens portion I can hardly read my panel. Also when I look out my driver's door window I see a colored streak down the middle of the window. (purple).
Earl
Old Dec 3, 2003 | 11:37 PM
acotam's Avatar
acotam
thanks guys! will play with it again!!!!
Old Dec 3, 2003 | 11:47 PM
MINIclo's Avatar
MINIclo
7th Gear Gal
>>You're right. I just got new glasses and with the magnetic clip on dark lens portion I can hardly read my panel. Also when I look out my driver's door window I see a colored streak down the middle of the window. (purple).
>>Earl <<
I see the same thing, Earl, with my prescription sunglasses on, which are polarized. (And I cannot see the digital readout on the tach unless I slide my shades down my nose and peer over them.) That purple streak thingie is freaky!
Clo/Wanda
Old Dec 5, 2003 | 10:40 AM
Antranik's Avatar
Antranik
It's past midnight, you got a 30 minute drive ahead of you before you are in the cozy bed and your eyes can't stand brightness. Dim everything down to a lull, and I start my sleeping before I get to bed. :smile:
_________________
-Anto. 2003 MINI Cooper S DS/B Bought 2/9/03. 16" R84 X-lite, DSC, MFSW, H/K System. It's All Excellent.
Mods: Pilo Racing Intake 5/24. Alta 15% Reduced Boost Pulley 7/10. Quicksilver Cat-Back Exhaust 8/18.
Wohnson89
Jun 10, 2020 04:53 AM
Dec 23, 2015 10:36 AM
ryGuyMCS
Oct 20, 2015 02:24 PM
oldkid6
Aug 11, 2015 08:13 PM
