R50/53 Dead Battery - Emergency Access
Old Nov 18, 2003 | 07:38 AM
MGCMAN's Avatar
MGCMAN
To those of you with a MCS: What means do we have to access the battery and change it if it goes dead with the rear hatch lock set? I'm thinking use the key to gain access via the driver's door, enter trunk by lowering rear seat backs, etc. any other means?
Old Nov 18, 2003 | 07:43 AM
chrisneal's Avatar
chrisneal
But aren't the locks power locks? They sure don't feel mechanical in any way.
Somewhere there's a big long thread on this.
Old Nov 18, 2003 | 07:44 AM
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
There should be an inside trunk release. Look in the manual. You will have to enter the car the way you were thinking though.
_________________
You can't be a real country unless you have a beer and an airline - it helps if you have some kind of a football team, or some nuclear weapons, but at the very least you need a beer. - Frank Zappa
Old Nov 18, 2003 | 07:52 AM
Phobol's Avatar
Phobol
There's a positive contact under the bonnet, next to the airbox. Connect your friend's car there and you can open the boot.
Also, just yesterday I did something really stooopid. I disconnected the battery and closed the hatch... Noone around, so I stuck my hand behind a rear seat, between the boot cover and the seat, and released the seat lock to drop the seat down. Then I lowered the second seat, dumped everything out of the back into the interior of the car, lifted the flap and connected the battery.
Whew! There's no emergency release pull on '02.
Old Nov 18, 2003 | 08:26 AM
apexer's Avatar
apexer
Of course you can also charge the battery using that same main 12 volt buss contact next to the air filter box.
Old Nov 18, 2003 | 03:12 PM
wkndracr's Avatar
wkndracr
If your car is a 10/02 or later build, you will have an emergency release under the rear seat. Just pull up on the front of the rear seat to pop it up and you will see a pull ring underneath in the center.
Old May 23, 2009 | 08:18 PM
Scoutd's Avatar
Scoutd
thank you thank you THANK YOU!!!
someone had to say it even if I'm 6 yrs into the future.
hate this car
schr5530
Oct 5, 2015 08:28 AM
schr5530
Oct 1, 2015 05:11 PM
dutchhome
Sep 30, 2015 07:17 AM
MiniSMan
Sep 29, 2015 06:38 PM
jennster
Sep 28, 2015 06:19 PM
