R50/53 Strut Bar and Oil Changes
Old Feb 18, 2010 | 09:54 AM
NeilHernandez's Avatar
NeilHernandez
I want to install a strut bar to my MCS engine bay, but it seems like it would interfere with me doing oil cartridge changes every time i change the oil (5k). I would hate to have to remove the strut bar every time i change the oil as that would seem like a hassel. What do you guys/gals do to make this easier?
Old Feb 18, 2010 | 11:16 AM
kishg's Avatar
kishg
the M7 strut brace seems to solve that problem quite well.
Old Feb 18, 2010 | 01:50 PM
Crashton's Avatar
Crashton
It only takes 4 minutes or so to remove the M7 brace. A strut bar will definitely be in the way at oil change time.
Old Feb 18, 2010 | 02:12 PM
quikmni's Avatar
quikmni
Why do you want to add a top strut bar? I believe the benefits will be minor and it will be in the way for oil changes. I change my oil frequently so it would be a pain. If wanting to add the bar to protect against strut tower mushrooming, just add tower reinforcement plates or camber plates instead of a bar. If adding the bar for improved handling, I would instead suggest a lower strut brace.
Old Feb 18, 2010 | 03:09 PM
Fatherdeth's Avatar
Fatherdeth
The M7 strut bar can be removed very easily as stated above. I just removed mine about 2 weeks ago for an oil change. I can, however, still do the oil change with it on. It's a pain, but can be done. If you are trying to improve handling, then the bar would provide some results. It's an up in the air thing about whether the bars actually help or not. You can really tell it works on a car that has no suspension work done on it. On a lowered car, you can"t tell so much. The fact is, anything you do to brace the car is a good thing.
Old Feb 18, 2010 | 03:33 PM
ZippyNH's Avatar
ZippyNH
One overlooked mod that helps (IMO) about as much as a strut bar are the cabrio strut braces when added to a non-cabrio....subtle, but noticable...they also stablize the strut towers. At about $50, they are a great mod IMO. Some say they are a waste of money... Just depends if you drive with finesse IMO, you will notice the change.
Old Feb 18, 2010 | 04:13 PM
Fatherdeth's Avatar
Fatherdeth
+1
Old Feb 18, 2010 | 05:30 PM
kishg's Avatar
kishg
do you mean the cabrio strut tower support rails shown here:
http://www.outmotoring.com/mini-coop...tible_r52.html
Old Feb 18, 2010 | 05:35 PM
Helix13mini's Avatar
Helix13mini
Yup those are the ones. Have you done a rear swaybar? That would be a better investment.
Old Feb 18, 2010 | 06:02 PM
kishg's Avatar
kishg
it would help to have a mini first wouldn't it? hehe i'm picking up my 2006 mcs soon. planning some mods. will definitely do 19mm rear sway and something to counter the mushrooming. either the strut tower reinforcements or the m7 bar. thought about those rails but figured it was overkill on a mainly street driven car (it will do some track time when i'm too lazy to tow my racecar )
Old Feb 18, 2010 | 09:53 PM
Some Guy's Avatar
Some Guy
Counter both understeer and mushrooming at the same time by getting a set of IE fixed camber plates. Bumps camber from anywhere between .4-.6 degree up to about 1.6-1.8 degree. The plates are beefy too so they prevent mushrooming. A set of IE plates runs about $180 new plus a front end alignment after install. If you factor in the alignment you probably end up around 230-280 out of pocket.
Old Feb 19, 2010 | 02:35 AM
Fatherdeth's Avatar
Fatherdeth
Good call!! This was practically the first thing I did to my '05 when I got her. I bought her with mushroomed towers. MINI fixed the towers and I installed the IE fixed camber plates and M7 strutbar. Very good investment.
Old Feb 19, 2010 | 04:46 AM
THE ITCH's Avatar
THE ITCH
Doing oil and filter changes with a strut brace in place is not a problem. I do mine from the bottom. It is not really a big deal.
Steve
Mikli
R55 :: Clubman Talk (2008+)
Jun 26, 2019 05:58 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
