R50/53 2006 mini checkmate S ?
Old Jan 7, 2010 | 03:14 PM
miniwheels's Avatar
miniwheels
hello, just picked up today a 2006 mini checkmate S model, with the checkmate package did any engine upgrades come with it? this one has a airbox lid that reads john coopers works? it looks like it still has the stock exhaust, with beer can tips.
thanks for any info on the checkmate.
mike
Old Jan 7, 2010 | 03:57 PM
Brewmeister's Avatar
Brewmeister
Checkmate
Welcome to the checkmate club!
Old Jan 8, 2010 | 08:58 AM
astrochex's Avatar
astrochex
The Checkmate package does not touch the engine. The airbox is at least upgraded to the JCW, which is a good thing.
Enjoy your checkmate!
Old Jan 8, 2010 | 03:48 PM
lawmann's Avatar
lawmann
Coordinator :: Middle Georgia MINIs
I personnally think the Checkmate was the best of the special editions when you consider the interior package and clean graphics.
Congrats on your purchase! How many miles are on the odometer?
Old Jan 8, 2010 | 04:11 PM
miniwheels's Avatar
miniwheels
thanks for the welcome, 46,000 blue and silver, even have delivery build sheet.
Old Jan 8, 2010 | 04:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Congrats, I always liked the checkmate interior.
Old Jan 8, 2010 | 04:24 PM
miniwheels's Avatar
miniwheels
now if i only can get the 2nd key fob to work? need to see one opened up, maybe can clean the contacts?
Old Jan 8, 2010 | 06:32 PM
Brewmeister
Could be it just needs a charge...
Old Jan 8, 2010 | 06:40 PM
miniwheels's Avatar
miniwheels
all my searches come up with that suggestion also. well i drive 2 hours a day, how long does it need? still do not understand how? there is only one contact point? unless it is completing the electrical circuit when the key is inserted? like a simple pull circuit?
Old Jan 8, 2010 | 06:54 PM
miniwheels's Avatar
miniwheels
ok here is the technical info
The new key also had three buttons, but, the LED did not carry over. is permanantly sealed and contains a rechargeable battery. Supposedly the battery should last the life of the car. The battery is recharge when in the ignition via the EWS ring antenna.
http://www.bmwgm5.com/Keys.htm
Old Jan 8, 2010 | 06:55 PM
miniwheels's Avatar
miniwheels
Recharging the battery in the new key fob. If not used the key will be discharged in approximately 18 months. It requires approximately 30 hours to fully charge a completely discharged battery. The remote can be operated 15 times after being charged for 30 minutes. Charging only occurs when the ignition is in the Accessory or On positions. It does not charge in the Off position.
Old Jan 8, 2010 | 06:56 PM
WayMotorWorks
Vendor
Call me I'll walk you through some tricks and we'll see if we can get the key to work.
WAY
317.201.8670
www.waymotorworks.com
Old Jan 8, 2010 | 07:09 PM
miniwheels's Avatar
miniwheels
when is a good time to call? thanks it frustrating, tried the turn the key on, off, out key unlock hold lock 3 times thing? no luck well at least one key fob works.
thanks for your help, mike z
Old Jan 8, 2010 | 07:14 PM
WayMotorWorks
Vendor
Call me at the shop tomorrow
WAY
317.201.8670
Old Jan 8, 2010 | 09:26 PM
ntmid8r's Avatar
ntmid8r
Awsome Color combo and interior.
I have basically the same car, without the Checkmate package...Space Blue, Silver roof, Silver Checkmate Bonnet Stripe,silver mirror caps.
I'm just missing the seats, steering wheel and fender badges. I guess I got the left overs.
Old Jan 9, 2010 | 04:32 PM
miniwheels's Avatar
miniwheels
thanks way for your help with the key fob, i took the jcw airbox lid off, as i noted the vac line and power was not hooked up! the flap was closed, ok i did the flap open mod, then i noticed no hole was ever cut for the incoming air on the engine back wall! who what a difference in sound, did not go for a ride yet, thanks again NJ mike
Old Dec 16, 2018 | 01:13 PM
Jeff Oligs's Avatar
Jeff Oligs
Key fob battery connection breaks
note that if you drop the key fob on the ground the weight of the battery inside will often break one of the solder joints connecting it to the pwb. Open it up and do some microsurgery
Old Dec 16, 2018 | 08:04 PM
ssean72's Avatar
ssean72
Welcome to NAM and the Checkmate club, post up some pics
bigramdizzle
Aug 6, 2019 09:19 PM
SosoMINI
Nov 22, 2015 03:17 PM
CARdiac
Aug 8, 2015 03:30 PM
sungjk
Aug 5, 2015 08:23 PM
rphox2003
Aug 5, 2015 11:34 AM
