R50/53 Octane Requirements
Old Jan 19, 2010 | 10:01 PM
  #651
howsoonisnow1985's Avatar
howsoonisnow1985
Not this again
Please go buy a honda
Ok Keep putting 87 petrol on the MINI
More Info Sticky Here: https://www.northamericanmotoring.co...emium-gas.html
Old Jan 20, 2010 | 03:46 AM
  #652
DOT191's Avatar
DOT191
We have used 89 octane in our 2003 Mini R50 since we purchased it &took delivery in March of 2003. Runs just fine
Old Jan 20, 2010 | 05:50 PM
  #653
tekron's Avatar
tekron
I have used solely premium gas for a very long time.. usually 92 or 93 if available. I just filled up my tank with regular just to see how the car would react and I'm getting better mpg... I'm probably just going crazy though.
CRAZY IN LOVE
Old Jan 20, 2010 | 06:10 PM
  #654
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Originally Posted by howsoonisnow1985
Not this again
Agreed.
This topic has been discussed to the point of nauseam. But in the interest of those who have not been here before, threads are now merged.
Thanks,
Dave.
Old Jan 20, 2010 | 10:45 PM
  #655
ROADDEVIL's Avatar
ROADDEVIL
ITS SAYS RIGHT IN THE BOOK. "91 OCTANE OR HIGHER ONLY"
if you use lesser you can do damage to your motor
hell, my mini has a sticker on there gas door that says it
and besides i get 450 miles on a fillup so who cares about the price of what goes in it, you'll make less stops
Old Feb 2, 2010 | 08:28 PM
  #656
ZippeeGear's Avatar
ZippeeGear
In the Vegas heat, I find that 92 octane works best for me in the summer time.
Old Feb 3, 2010 | 05:59 AM
  #657
ZippyNH's Avatar
ZippyNH
Like Way for WayMotorWorks said....he has swapped a few motors, and the ones that used low octane looked pretty bad....It does have an effect....eventually you may need a head, piston, valves.....89 is pretty close to 91...the anti knock sensor can most likely retard the timing enough to be OK for the near team....but 87...Coommmmonnnnn!! Don't go there!! A bit out of spec...the engineers must set some wiggle room....but 87 to 91....might as well run disel, and see what happens!!
I hate to say what has been said a million times, but I don't want a newbie to blow up a motor and have a $5000 bill because thy thought it was OK....
What amazes me is people all believe that MINI says use synthetic oil...most everybody does....with little debate. Why the debate here? If you believe them on one, why not the other?!
Old May 9, 2010 | 03:56 PM
  #658
grc123's Avatar
grc123
Originally Posted by AllBlack05S
ps is there a reason you change what you type to bold and a larger font than the default?
Yes, it's just easier (and quicker) for me to pick-out and read-back what I've written (at age 50 I'll take whatever 'ease-of-use' I can get).
I usually check-back later to see if the words I posted are actually the thoughts that I was trying to convey.
I actually don't believe I've ever changed the size of the font, but yes I do tend to embolden it.
If I had my way we would all have different colored and more personalized (styled) font.
I "try" to only do this on threads that I've actually started.
Hopefully it doesn't cause anyone any problems.
bahman
Feb 14, 2016 10:29 AM
papawhiskey
Sep 30, 2015 02:50 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
