R50/53 MCS Strut Identification/general Question
Old Nov 9, 2009 | 12:56 PM
El Gato Malo's Avatar
El Gato Malo
Hello,
I'm looking to purchase some new(er) struts for my '04 MCS.
The owner says that he definitely got them in '06 (so they aren't from an R52) but he doesn't know what model they came from (S vs Non-S model). Does this matter for my application?
If it makes any difference, they are stock Delphi struts [/FONT]with this # stamped on them:
Delphi RQ2 22191212
Delphi LQ2 22191213
I'm sill waiting to hear back on if an 11 digit part number is stamped on them.
Old Nov 10, 2009 | 04:38 PM
El Gato Malo
Anyone?
Old Nov 10, 2009 | 09:22 PM
howsoonisnow1985's Avatar
howsoonisnow1985
You can also verify with http://www.realoem.com/bmw/select.do
What I do know is that for each suspension system they make 3 versions (soft, medium, & hard) of springs for it, depending on what options (weight based) your car has, you get a specific spring (rate). But realoem will only give Part Number, its usually on a white sticker. Sport or Non-Sport really only matters to the owner/driver and what you prefer a softer non-sport or a stiffer sport suspension. And the same goes for the spring, for example when my JCW suspension goes I am borrowing a VIN number to get the hardest spring rate, despite having the lightest oem R53.
Old Nov 11, 2009 | 12:30 PM
El Gato Malo
Thanks for the info. That OEM parts website is a godsend.
I called up my local BMW dealer's parts department and spoke to them about the struts. They seem to match up just fine with an S series car, so I'm hoping that the numbers don't lie!
Old Nov 11, 2009 | 03:54 PM
howsoonisnow1985
I found some really obscure MINI parts in realoem, just have to dig deep. For example, for front struts its under "front axle" and rears its under "rear axle."
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
massmini03
Aug 12, 2015 11:19 AM
nomar116
Aug 10, 2015 11:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
