Yes there's chatter Jeffreyevens. If you want a refined sound(no noise at all) like stock the FX200 won't be for you.
Jeremy
Jeremy, My stock clutch has been chattering for 3+ years. If the CM setup is the same or a little more it won't matter, the pro's of this clutch/flywheel will be worth it. Anyway how much time do you really spend in neutral
Thanks for the reply. Happy Motoring, Jeff
Jeff neutral is your home if you're MINI's motor is running and awaiting forward or aft movement. At least you're chatter broken in then! Have fun with the CM clutch!
