R50/53 Passenger door wont open from inside
Old Dec 27, 2008 | 10:45 PM
arizona29's Avatar
arizona29
Replaced a blown speaker on the passenger door and now that door has a hard time opening from the inside. Sometimes it works perfectly most of the time it doesnt. Any suggestions on how to fix this?
Old Dec 28, 2008 | 01:12 AM
adrianr's Avatar
adrianr
check that all connections are connected properly, and that the door fuses are ok, etc. im not a pro or anything but i think its a false contact.
good luck with it.
Old Dec 28, 2008 | 07:56 AM
healey67's Avatar
healey67
Remove the door panel again and check the cable that runs from the inner handle to the door lock actuator, sounds like the cable came out of its holder.
Old Dec 31, 2008 | 03:52 PM
arizona29's Avatar
arizona29
Hey you replied to my issue im having with my door not opening, i took off the panel and didnt see anything wrong but maybe i dont know what im looking for when u say "check the cable that runs from the inner handle to the door lock actuator, sounds like the cable came out of its holder."
if you could explain a bit more id apreciate it.
thanks
Chris
Old Jan 1, 2009 | 01:40 PM
MiniMaxx's Avatar
MiniMaxx
On the exterior door handle, make sure the black plastic mash bar (for lack of the proper term) has returned fully to its original position. I know when its cold, I have to snap it back after opening the door from the outside.
Old Jan 1, 2009 | 01:49 PM
arizona29's Avatar
arizona29
Works now, found out the wire cable with the black tubing protecting it was slacked, so I pulled it a bit tighter and now the door works amazing, used to be the window sealing mech only worked some of the times (door would still open) now it works like new
Thanks for your guys' help
SheldonCooperS
Aug 25, 2015 11:57 AM
polotska
Aug 23, 2015 03:03 PM
missinmyjeep
Aug 22, 2015 07:13 PM
chicohuahua
22
Aug 20, 2015 11:17 AM
