R50/53 Draining windshield washer reservoir
Old Dec 18, 2008 | 06:34 AM
hugh's Avatar
hugh
I want to remove the fluid and replace it with a better product. The stuff in there now froze @ 32f. Is there an easy way to drain it or should I just squirt out what's in there?
Old Dec 18, 2008 | 07:23 AM
AggieMini11's Avatar
AggieMini11
Im wondering the same thing.
Old Dec 18, 2008 | 07:33 AM
not-so-rednwhitecooper
Remove the inner fenderwell and pop off the motor, it will all pour out.
I wouldnt squirt it for that long, you don't wanna burn up the motor.
Old Dec 18, 2008 | 07:39 AM
Yo'sDad's Avatar
Yo'sDad
Stuff a little plastic tube in from the top and siphon it out.
YD
Old Dec 18, 2008 | 03:34 PM
Capt_bj's Avatar
Capt_bj
Assuming your bottle is not full....
Either go to the auto part store and buy a bottle of concentrated wash mix
or
go to the drug store and buy a bottle of denatured alcohol
or decant about a half cup of anti-freeze
and dump it in......
then the next day after driving a bit and assuming the lines are unfrozen, pump fluid thru the lines for 30 seconds or so.....
Old Dec 18, 2008 | 03:46 PM
markjenn's Avatar
markjenn
I don't see any way you're going to be able to get the water out with getting it unfroze and once you've warmed up the car to do this, then I'd just use the system to get the water out and replace with the good stuff.
You may have other issues though - cracked lines, cracked tank, ruined pump.
- Mark
Old Dec 19, 2008 | 03:55 PM
hugh's Avatar
hugh
or
Thanks everyone for your suggestions !
I like the antifreeze idea. I'm not sure what you mean by 'decant'
Old Dec 20, 2008 | 05:29 AM
Capt_bj's Avatar
Capt_bj
1 : to draw off (a liquid) without disturbing the sediment or the lower liquid layers 2 : to pour from one vessel into another 3 : to pour out, transfer, or unload as if by pouring
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
MGBill1186
Oct 2, 2015 06:54 AM
aldito2
Sep 30, 2015 10:44 AM
