R50/53 Turn off A/C, serenity now!
Old Sep 10, 2008 | 02:59 PM
MiniKJ's Avatar
MiniKJ
Hi y'all:
I wonder if y'all notice a serene waterfall sound after shutting off engine. The sound is coming from the A/C unit behind the glovebox. You know, the sound you hear at a dental office in the waiting room, with the miniature waterfall/stream. That's what mine sounds like after shutting off the A/C and engine. I am hoping that's just the condensation draining from the compressor.
I almost fell asleep while waiting for my wife and listening to the creek.
Old Sep 10, 2008 | 03:32 PM
chaseabryant's Avatar
chaseabryant
I found that my coolant returning to the coolant tank sounded like that when turning the car off. Unfortunately, that was when my coolant was really low also (had a leak) I suggest just having a look at your coolant tank to make sure it is still as full as it should be.
-Chase
Old Sep 10, 2008 | 05:06 PM
MiniKJ's Avatar
MiniKJ
Thanks for your advise. I will check it tonight.
Old Sep 10, 2008 | 05:22 PM
bond007's Avatar
bond007
-Chase
That's what it is. I had the same thing happen on a Land Rover Discovery ll and it was caused by a very low coolant level,(I didn't had it checked in months).
Old Sep 10, 2008 | 07:02 PM
cxg's Avatar
cxg
If it was a Disco... it was leak
sorry, we love our Land Rovers, have an 03 Disco and an 06 Range Rover, but they need TLC.
Old Sep 11, 2008 | 10:43 AM
MiniKJ's Avatar
MiniKJ
I checked the level with engine cold in the garage, it was slightly below MIN. I know it needs to be checked when hot, so I will check again at normal temp. There's no sign of leakage so far anywhere. No puddle, no greenish white powder around hose connections. So, if it needs top off, I hope this is just a normal loss of coolant after almost 3 years. It's due for change this winter anyway.
Thanks everybody.
Old Sep 11, 2008 | 11:47 AM
MINIdave's Avatar
MINIdave
I think you were just hearing the equalization of the pressures in the A/C system thru the expansion valve...........it's a pretty normal sound. Most people don't sit in their cars quietly after shutting off the motor, we get out and go, so we wouldn't usually hear this.........
Old Sep 11, 2008 | 01:18 PM
MiniKJ's Avatar
MiniKJ
That's what I initially leaned toward as well. What other folks brought up was also good advise to keep my eyes on. Yeah, I wait for my wife often in a garage, and just feel like having some quietness sometimes...
Old Sep 11, 2008 | 01:25 PM
gokartride's Avatar
gokartride
I have heard a gurgling sound when shutting off the engine on my R50 that related to coolant levels...apparently to properly fill the system one must access several points on the engine and if this is not done, the system may make this sound as it is not full. I don't beleive this has anything to do w/ the AC though...so you may be hearing something else.
Old Sep 11, 2008 | 09:18 PM
MiniKJ's Avatar
MiniKJ
I was actually wrong about checking the coolant level when the engine is warm. Just checked the owner's manaul, it's supposed to be checked at ambient temp. That also means mine is too low since it's below the MIN mark. A trip to the dealer tomorrow then
rob&JCW
Feb 21, 2018 02:41 PM
Supertractor3
Apr 7, 2017 11:16 AM
rob&JCW
Oct 9, 2015 11:12 AM
doug5g
Sep 2, 2015 04:53 PM
Suspension Products
Sep 2, 2015 10:32 AM
