R50/53 R56 Front Brakes on an R52
I bought a set of R56 front brakes for my R52 because the seller said they're the same as the JCW brakes except not red and will fit just fine.
This afternoon the installation went very smoothly until I tried to attach the brake lines. They won't fasten because there are no threads inside the hole on the caliper where the lines attach.
Now I'm down unless I either undo the install and re-install the original brakes...
Can anyone here help me out?
What am I missing? Did I throw away $350?
I'm waiting to hear from the seller and wanted to check here to see if anyone has done this swap and can bail me out.
Thanks!
Thanks!
just need the R56 lines. See this link, https://www.northamericanmotoring.co...d.php?t=112474
You got a deal, wish I could find a set.
By the way, we do have Carbotech pads for the R56 brakes.
One more thing... what about the lack of thread inside the hole on the caliper? From the photos I can find of R56 brake lines, I'm gonna need threads, aren't I? Or am I missing something?
Thanks for asking. There are two great street pads from Carbotech.
Bobcats, are the low dusting, better stopping them OEM pad, a fav for street and AutoX owners that like clean wheels.
AX6 are pads designed for AutoX and stop as if you had dropped an anchor out of the boot
. About the same dust level as OEM, but STOP NOW!All the CT pads are rotor friendly and still hand made in the states
Also note when your R56 OEM Rotors need replacement, that the NEW TSW OEM replacements will be ready to ship too.
Might as well get the Goodridge steel line or Helix for R56 AutoXCooper might have them and probably cheaper than oem.
Thanks to all for your suggestions and advice!
http://www.autoxcooper.com/ie_suspension.html
thebordella
Aug 31, 2015 01:37 PM
