R50/53 Hammering down a mushroomed tower
Old Aug 5, 2008 | 10:38 AM
SteveB625's Avatar
SteveB625
For those that have done this, how much hammering did it take to mash the mushroom into submission?
My pass side has the strut studs splayed out just enough to make it difficult to install the Craven plate.
I'm thinking the best way is to jack up the corner to let the wheel hang and have at it with a 5# sledge on a block of wood placed on the raised portion of the tower.
Any words of wisdom would be greatly appreciated.
On the plus side, the driver's side plate went on without difficulty.
Regards,
SteveB
Old Aug 5, 2008 | 10:49 AM
ScottRiqui's Avatar
ScottRiqui
That's exactly what I did on the mushroomed passenger-side tower on my wife's car. It didn't take much force, and I went slowly so as not to overdo it. I seem to recall it taking about a half-dozen "whacks" over various parts of the tower to get it flattened back out.
Old Aug 5, 2008 | 07:53 PM
k-huevo's Avatar
k-huevo
The guide support should be replaced, it will have deformed along with the tower sheet metal. Reshape the tower with the strut removed; it won’t take a big hammer, just firm strikes.
Old Aug 5, 2008 | 10:14 PM
pmustang's Avatar
pmustang
You are 100% on the right track, that is exactly how I did mine, Took about 15/20 strikes on each side, Watch for hitting the headlight assbly on the upswing!!! I used a much larger sledge (longer handle) I think the small one would have made life easier, But it went down perfect and with the cravens (which is what I was installing) you have the perfect guide on how far to go.
Peter
Old Aug 6, 2008 | 02:48 AM
SteveB625's Avatar
SteveB625
Thanks for the feedback. I guess hitting the headlight ***'y could result in an expensive problem (w/ xenons). "K", thanks for the pic.
Its too bad this is even a problem. These are neat little cars and this "seems" to be about the dumbest (for lack of a better term) issue from an engineering standpoint. I had a '72 240Z in which I transplanted a 350 Chevy engine. The struts and towers never deformed, but the floors rotted right out of it. There's always something. I did rebuild that car from the ground up, though.
pmustang, how's your issues? Did you get your MINI fixed up OK?
Old Aug 6, 2008 | 09:08 AM
rynegold's Avatar
rynegold
error/15690
Old Aug 6, 2008 | 09:16 AM
mauberley's Avatar
mauberley
Basically, extremely rough roads, hitting potholes...
And to fix it, you hammer it down as described in the thread... to prevent it, common opinion is to either get strut tower plates, or fixed camber plates.
Old Aug 6, 2008 | 09:26 AM
Xymox's Avatar
Xymox
...or both.
Old Aug 6, 2008 | 09:32 AM
mauberley's Avatar
mauberley
I said "or," not "xor."
Old Aug 6, 2008 | 09:46 AM
SteveB625's Avatar
SteveB625
mitch,
As a complete newby myself, I made sure to look at the towers before purchase. They really did not look "out of whack". Not knowing exactly what to look for didn't help.
You need to look at the 3 studs protruding up from the strut. They should all look perpendicular to the mounting surface and parallel to each other. If they look like they're pointing away from the center hole, you have mushrooming. A picture is tough because you could use a fisheye lens and duplicate the same thing. The best way to photograph it would be to use a square or some other reference object near the studs. A straightedge might help if photographed on a known good tower and then a mushroomed one. Its probably been done already...
Old Aug 6, 2008 | 05:19 PM
k-huevo's Avatar
k-huevo
There are many discussions on NAM with good photos; here’s another from MINI2 http://www.mini2.com/forum/faults-fi...shrooming.html . I’m also one who does not put any faith in above tower plates.
ericbryant24
55
Sep 30, 2024 02:10 PM
YaTuSabe
Aug 23, 2018 11:41 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
rt808
Sep 29, 2015 03:15 PM
wyliec0y0te
Sep 15, 2015 01:13 PM
