R50/53 Question on 03 S climate control area and some others
Old Jun 2, 2008 | 08:45 AM
smi2710's Avatar
smi2710
Our mini has developed a problem with the air ciculation button its always lit so that the cabin air is recycled not fresh and with summer just about here it need to get fixed
anyone have this problem before ?
wife to the car to the dealer one day they said it would have to be replace the whole control unit - if so who has a good used one
and also now the ac doesnt blow cold i could possibly needing a recharge it 5 years old but we only have 56k on the clock and its not like its florida where we run it year round
can i just recharge it with the r134 stuff from a auto store ?
and one more question the sunroof stopped opening with one press and we know have to hold it the entire time while it opens
sorry for all the questions
Old Jun 2, 2008 | 08:54 AM
AutoXR53's Avatar
AutoXR53
Chances are if they told you the control unit is bad. It is. Might want to check e-bay for something like that.
As far as using the r134a from the parts store in the cans. Don't do it. You can actually overcharge the system and either make the system run worse due to the increased pressure, or even damage it. I've seen it a lot where I work. I know some people have done it. But I definately wouldn't. Also if you get the a/c recharged they can add a dye to it to see if it is leaking anywhere if it every stops working again.
The sunroof... could be a few things, the switch the stop motor. I would try cleaning and lubing the tracks, that is all mine ended up needing.
Old Jun 2, 2008 | 08:59 AM
tshubin's Avatar
tshubin
Auto a/c control or not?
Do you have the auto a/c ? If so, i think i have a barely used hvac control unit in my garage (<5000 miles).
Send me a PM and we'll make it happen, on the cheap!
Old Jun 2, 2008 | 09:19 AM
smi2710's Avatar
smi2710
they didnt look at or test it, they just assumed thats why i was asking maybe i should takeit apart and look at the contacts
and what is this unit called so i can start searching for a new one
thanks
Old Jun 2, 2008 | 09:29 AM
AutoXR53's Avatar
AutoXR53
Most dealerships do a full diag. on the system if something is inoperative. That is what we do at the dealership where I work, even if it goes over the diagnosis time we quote the customer.
Old Jun 2, 2008 | 04:49 PM
tshubin's Avatar
tshubin
smi2710, you have a PM
Old Jun 3, 2008 | 07:57 AM
smi2710's Avatar
smi2710
thanks tshubin
you can email me today so we can get this going
Old Jun 4, 2008 | 04:37 PM
nickel1981's Avatar
nickel1981
try pushing up on the button, like tilt position. do not release the button, hold it down and the sunroof will go through all its positions. if that does not fix it, it may be a software issue.
Old Jun 6, 2008 | 07:16 AM
smi2710's Avatar
smi2710
thanks i will try that
and tshubin where ya at ?/
if anyone else out there has the hvac control unit im looking for let me know
its the one that looks like a mini logo
thanks
eatsleepautox
Oct 30, 2015 06:46 AM
Zettinger
Aug 25, 2015 04:04 PM
ludedude
Aug 10, 2015 07:16 PM
2manyhobbies
Aug 9, 2015 06:02 PM
