Ok, OK. Here it is from the top. I have a MINI. It came with a tire jack. the tire jack is in a pouch. The pouch is rolling around in the trunk. Questions are as follows:
Where is the boot?
Where does the pouch strap to?
If it's loose, it belongs in the pouch. If it's in the pouch, the pouch has hooks on it that secure it in the boot.
That probably makes no sense at all.
+1
There are a couple of different places the hooks will go. Just survey the area and pick two - mine secures nicely in a lengthwise (north/south, front/back) configuration.
Where is the boot?
it goes in the trunk.
the straps are on the pouch and they can be hooked onto the 2 eyelets in the trunk. there are 4 eyelets, 2 on the driver side, 2 on the passenger side.
Where is the boot?
The eyelets on which to hook the jack pouch are fairly obvious.
As an alternative, you can get a boot box and leave it in there.
The boot IS the trunk (it's a Brit thing)
boot = trunk
hood = bonnet
wrench = spanner
My jack is in the pouch and inserted in the driver's side compartment in the hatch - not rolling around and not taking up cargo space, but hidden in that compartment on the driver's side. It takes a little twist to get it in there, but it fits great, and doesn't roll around.
Where is the boot?
Boot is British for trunk.
That pouch has two straps with hooks. When delivered mine had the non-elastic strap hook hooked to the metal tie down loop behind the driver's side rear seat and the elastic strap hook hooked to the metal tie down loop that lines up with it nearer to the rear bumper. That's about the best description I can give without taking a picture.
I don't really know why it's still in my boot though. I can't think of a situation in which I'd use it.
Ok, OK. Here it is from the top. I have a MINI. It came with a tire jack. the tire jack is in a pouch. The pouch is rolling around in the trunk. Questions are as follows: Where is the boot?
From what I gathered (being a new MINI owner myself), I believe the "boot" is the trunk. I'm still not sure why it's call boot, but hey, everything has gotta be different on the MINI, right?
If I'm in Great Britain and driving on the "wrong" side of the road, it's a boot. To me it'll always be "the hatch", "the trunk", "in back". I've found using the word "boot" with non-Motorers almost always produces a question or (more often) an eye roll, and quite often both.
I have no idea what we need a jack for with an MCS. Yes. my MCS came with one. Nope, no spare. Having the jack in the boot seems usless. I have a floor jack at home for when I want to rotate the tires (much faster and safer).
