R50/53 Question re: 36mm filter cannister socket
Old Jan 30, 2008 | 02:05 PM
JAB 67's Avatar
JAB 67
I need to purchase the 36mm socket to undo the filter cannister on my 2004 MCS. The sockets specifically intended for this purpose are 6 point. Sears sells a 36 mm socket, but its 12 point. Will it work? Ill-advised? TIA.
Old Jan 30, 2008 | 02:39 PM
miniconcarne's Avatar
miniconcarne
I used a Craftsman 12 point and didn't have any issues.
Old Jan 30, 2008 | 04:45 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Buy the cheapest 36mm socket you can find. They are usually too deep so I cut mine down with a hack saw and then cleaned it up with a file. Works great. 6 point or 12 point doesn't matter.
That said search eBay for 36mm socket and you'll have a bunch of very reasonably priced choices all ready short. Get one with a 3/8th rather than 1/2 drive as you'll probably find that easier to get in.
Rich
Old Jan 30, 2008 | 06:06 PM
verveAbsolut's Avatar
verveAbsolut
+1. Make sure you have a 1/2" drive ratchet to use with it...I haven't seen any 3/8's drive 36mm up at Sears.
Old Jan 30, 2008 | 06:13 PM
JAB 67's Avatar
JAB 67
Thanks everyone. The Sears socket is relatively short, 1/2" drive. I have ratchets in both 3/8 and 1/2, and adapters if necessary.
Old Jan 30, 2008 | 06:56 PM
minimarks's Avatar
minimarks
Autozone, Advance, Pep Boys etc has them..
Old Jan 30, 2008 | 10:50 PM
Motor On's Avatar
Motor On
It tends to be too tall with adapters unless you cut it down.:impatient Just give yourself plenty of extra time the first few times until you have the no leak loosen trick down pat and you should be good.
Old Jan 30, 2008 | 11:06 PM
verveAbsolut
If you're referring to the socket...negative. Here in Baton Rouge, Autozone, Advance, O'Reilly, and Pep Boys only had the deepwell 36mm axle nut breaker.
I had to head to Sears and Sears alone. Neither Home Depot nor Lowe's had it either.
- Matt
Old Jan 30, 2008 | 11:56 PM
Eric_Rowland's Avatar
Eric_Rowland
12pt isn't an issue - you're not putting much torque on it.
It will just fit with a 1/2" wrench, but I cut down my Sears socket as well, but with at dremel tool.
Old Jan 31, 2008 | 06:12 AM
cristo's Avatar
cristo
Alliance Member
... and you won't use very much torque putting it on.
... but you might need a breaker bar and some muscle starting to
take it off depending on who put it on last.
Old Jan 31, 2008 | 05:08 PM
javelina1's Avatar
javelina1
got the one from Sears too... works fine.
Old Jan 31, 2008 | 05:13 PM
SlowGSX98's Avatar
SlowGSX98
I've used to Sears socket for my last 2 oil changes and haven't had any problems
Old Feb 1, 2008 | 07:25 AM
rhawth99's Avatar
rhawth99
I had a 36mm socket from Sears that worked fine on my '06 MCS. It was too long (lack of clearance) on my wife's '05 MCSa. The automatic must shift the engine over about 1/2" to 3/4" to the passenger side compared to the stick. The socket wouldn't clear the plastic well once you started to loosen the cannister. I went to PepBoys and they had a short 36mm socket that worked great. Couldn't find a short 36mm at Sears.
Old Feb 1, 2008 | 07:35 AM
agranger's Avatar
agranger
On a R50 MC (02 to 06) any standard sized 36mm socket will work just fine. On the R53 MCS (03 to 06), you will need a 36mm shallow socket because there is less clearance behind the filter. I paid about $6-8 for mine at PepBoys. They sockets were shelved right next to the oil filter wrenches, not on the tool and socket isle.
Old Feb 1, 2008 | 09:04 AM
thulchatt's Avatar
thulchatt
I have the Sears 36mm and use it on my 04 MCS. There is not much room with a 1/2" drive, but it fits. I only use it for the first 1/4 turn and then do the rest by hand coming off.
Going back on it takes the socket to turn the filter down with the tight fit, but it is more of a process than needing to tighten the filter.
FWIT, it does not take anything more than hand tight for the filter because the seal is from the o-ring.
Old Feb 1, 2008 | 09:19 AM
Speedwing's Avatar
Speedwing
I bought mine on E-Bay from Evolution Gun Works (one of the best gun smithing companies in the US).
Kimolaoha
Jul 5, 2023 01:04 PM
polotska
Aug 23, 2015 09:10 AM
FLYM1N1
Aug 16, 2015 01:17 PM
minipopkart
Aug 13, 2015 05:22 AM
