R50/53 Magilla Gorilla on steroids worked on my car
Went out to the garage last night to do a simple "in between" oil change and tire rotation on my '05 S. However, the drain plug was in so tight I rounded off the bolt head trying to get it off and had to resort to vise-grips to get it off. Luckily the filter cannister came off with no issue.
On to the tire rotation. No problem on the left side, so on to the right. My impact wrench couldn't take off lug bolts off the right front. I have an 18" breaker bar and by me (165 pounds) jumping on it I was able to loosen the bolts. I estimate that was about 240 ft lbs of torque - about 3 X what it should be. The car was at the dealer last week getting a noise diagnosed in the right front.
I called the service writer to day to complain. Naturallly they admitted no wrong doing and told me that if I had brought the car to them instead of doing it myself I wouldn't have had these problems. However, he did state that they use airguns to tighten lugs and told me that the wheel bolt torque spec is 180 pounds. Yes, 180. Sounds about 100 pounds hight to me.
Bottom line: they are sending me a new drain plug and 4 new wheel bolts. I'm happy about that, but not about why they have to do it.
According to Bentley, the torque specs are like 87-93lb-ft per wheel bolt. Prolly somewhere near 200 lb-ft came out of that impact gun. Techs don't care when they're getting paid flat rate to fix your car. Instead of taking 5 seconds to get a torque stick to tighten wheels, they just balst them with their Snap-On gun on 11.
Son of Kong works at my dealership. Yep way tight drain plug & filter housing. I told the SA at my last service not to let son of Kong do it. I'll find out in another 5,000 miles if Kong was there.
I had to use an 18" breaker on my drain plug.
I am surprised that a Mini service center would use an impact gun to put wheels on. My dealer said that they do all wheel installs with hand wrenches.
I guess everybody is different. ;(
I suspect that they mistakenly believe that once the wrench clicks, it doesn't apply any more torque to the bolt.
[quote=Super Coop;1891164]Went out to the garage last night to do a simple "in between" oil change and tire rotation on my '05 S. However, the drain plug was in so tight I rounded off the bolt head trying to get it off and had to resort to vise-grips to get it off. quote]
Same thing happened to me, and used the vice grips also. So I switched to a fumoto valve. I think the drain bolt actually has too small of a head for the diameter of the threads.
That's a frustrating experience to go through, but unfortunately not all that uncommon.
I know MINI recommends about 90 lbs.ft. as the stock lug nut torque, but I torque mine to at least 110. For a car that can do 100mph+, 90 lbs.ft. just doesn't seem enough for me. Anyone feel the same?
Ah, for the days of knockoffs that simply spun on tighter as you drove. Wheel torque? Just carry a knockoff wrench and a BIIIG hammer.
I like the idea of the fumoto valve, just not sure I trust them...............
Buy a 6 point socket from Sears for $6 or so and use that on your drain plug, then you won't round it off. Make sure the socket is squarely on the bolt and apply torque at 90* to the direction of the bolt. I've seen many people round things off by mis-application or using the wrong tool.
Never use a crescent wrench or channel locks on a drain plug...........
A little extra torque on the lug bolts won't hurt them, but getting them even is very important, hence the proper use of a torque wrench. If it took over 200 lb ft to get those lugs loose, I'd be worried that the threads were stretched and I'd consider replacing them.
https://www.northamericanmotoring.co...d.php?t=131129
Make sure to use either a six point socket or a six point box wrench. If you don't you run the risk of rounding the drain plug head off. Sometimes it helps to cuss a bit while doing this job.
BTW FWIW I do all my maintanence on my MINI and here are my results.
I hit my lugs with the impact driver set on middle setting about 50ftlbs and then torque to 95ftlbs (I autox alot and never lost a lug) I change my wheels alot. The oil drain plug (I replace everytime) is torqued to 25ftlbs and never a leak. I guess the Bently manual has good info in it. My $.02
Better than some methods I've seen, such as the "torque it 'till it strips, then back it off a quarter turn" philosophy...
Best,
T.
We torque the racer's wheels to 90lbs - these are VW's with alloy wheels and race slicks. They don't hit 100mph except at the ends of the straights but the cars do get tossed around much more extremely than a street car; race slicks can put a lot more lateral force upon a rim than DOT street tires are likely to see.
I'd stick to specs; Hondas were once known to get warped wheels with too tight lugs, I would wonder if over tightened lugs might even stretch just a little or be weakened or pull out of the hub?
Truest statement of the day!
