R50/53 Coolant Question
Old Sep 29, 2007 | 02:59 PM
T-Boy's Avatar
T-Boy
Coolant Question
'02 Cooper, low on coolant. Is it best to just buy the coolant from a dealer, or is there better prices on the net? In the Atlanta area if there are any shops local.
Old Sep 29, 2007 | 04:20 PM
resmini's Avatar
resmini
Prestone makes good antifreeze, along with a lot of others, and it's available almost anywhere.
Old Sep 29, 2007 | 06:17 PM
kapps's Avatar
kapps
Zerex G-05 should work fine as well.
Old Sep 29, 2007 | 07:39 PM
T-Boy's Avatar
T-Boy
thanks, but can all of these be mixed with the oem blue coolant? I know in my VW I have to use the VW stuff, if i mix it, it starts to gel.
Old Sep 29, 2007 | 07:43 PM
kapps's Avatar
kapps
I've mixed Prestone all makes all models with oem coolant and it was ok. G-05 should be even better. BMW coolant is G-48. I think you should be able to get G-48 at SAAB dealers for a lot cheaper than MINI sells it for.
Old Sep 29, 2007 | 07:51 PM
T-Boy's Avatar
T-Boy
thanks for your helpful info...
Old Sep 29, 2007 | 08:09 PM
resmini's Avatar
resmini
Mixing the coolant should be no problem. Some of the coolants even say on the bottle, "mixes with everything", or something like that.
Old Oct 1, 2007 | 12:35 PM
hemiheaded18's Avatar
hemiheaded18
Yeah, but sometimes you gotta be careful. If you mix any form of green AF with GM's DeCool crap, it turns to acid. Good for eating up gaskets really quickly.
Edit: I only paid about $20 for a gallon of full strength (2 gallons mixed) AF from a local Beemer dealer. Compare that to about $11-12 for Prestone at a retail store. Not bad, IMO. And, be sure to add a bottle of Redline Water Wetter.
Old Oct 1, 2007 | 01:59 PM
JeffreyC's Avatar
JeffreyC
And the coolant should be phosphate free. Using coolant with phosphates causes all sorts of issues with BMW motors. I doubt the Mini would be much different.
Old Oct 1, 2007 | 02:13 PM
MiNi_MaC's Avatar
MiNi_MaC
when i bought mine 02 MCS, my motoring advisor said i could use just any 50/50 antifreez... since then, ive been using prestone 50/50
Old Oct 1, 2007 | 02:52 PM
resmini's Avatar
resmini
Yep, no reason to use anything else.
speedyg56
May 18, 2020 08:52 AM
W0TM8
Dec 19, 2019 07:50 AM
Cereall
Sep 5, 2019 06:05 PM
theateist
Jul 2, 2017 02:21 PM
tylewis
Aug 18, 2015 06:53 AM
