Navigation & Audio Aux connection to OEM stereo
Does anyone know what type of connection the OEM stereo has for aux input? That is the type of plug that actually goes into the back of the radio.
Is it 2 RCAs, a regular mini headphone jack type, or large headphone jack type, or other? I'm planning on setting this up myself, and I would like to purchase all I need before I pull out the radio. I will be purchasing the parts myself at a local radio shack and doing some modifications for a very nice setup. I'll post pictures when I'm done and see what you guys think.
After you add the factory adapter (has like a 6pin plug) from dealer (about $40), the output is then regular headset jack that fits an ipod type device.. I think 1/8? (patch cable is same on both ends)
Back of stereo has no rca type plug just the 6pin thingie for the adapter.
It's pretty much the same price across the board. $39.99 at my MINI dealer, and the same at outmotoring;
http://outmotoring.com/mini_auxilary_audio_input.html
And you don't need to pull out the headunit, just remove the piece below the steering colum and you can access the back of the headunit. I plugged mine in in less than a minute.
https://www.northamericanmotoring.co...ad.php?t=88629
It is not just a straight wire connection, but has a simple circuit. The headunit enables Aux mode when it sees the circuit. See this: http://www.mini2.com/forum/interior-...le-sorted.html
The way it works is that if no aux cable is plugged in, AUX does not show up as you cycle through the modes. After you plug in the aux cable (even if no music player is connected to it), AUX will appear as one of the modes. The head unit detects the circuit in the aux cable.
I have an 03 built in the 1st week of the model year. Works fine on my car. If your car is an 03, you SHOULD be fine, but there are no guarantees.
The OEM Aux works great in my 03.
Pull open this panel to reach back of radio, install plug by feel.
I installed the input jack here. MINI says to put it in the glove box, which seemed like a silly place to me.
Mark
Mark
BEHOLD!
This may help: DIY Aux Connector
I did it last year and spent .50 at radioshack for the 1/8 female adapter. So I thought I'd do a little write up about it.
Shankrabbit...you are ****ing awesome! That is exactly what I was looking for! I was wondering how I was going to figure out which pins are for which function!
So you actually plugged in the wires directly to the pin hole?...and the part from the audio card was what you use to plug the ipod into right? My monitor at work sucks so the pictures are very dark. If I can simply...wait I have it...it's so obvious!
(sorry, I'm feeling a little ADD today)
The pins in the back of the HU are the same distance as the typical jumper pins you find on most electronic equipment. I've heard some people use the cable that runs from your soundcard to your CD-ROM drive too.
It's ok... I'm ADD everydBICYCLE!!!!
So here's my plan:
http://www.radioshack.com/product/in...entPage=family
Pin connectors for the R+ L+ and RL- Those will be spliced into a female 1/8" headphone jack input. That way I can plug a 1/8" cord with male on each side to the input!
I'll post pics when I'm done.
So here's my plan:
Here, I took one of the images and made it brighter so you can hopefully see it. (I added hand drawn side profile too).
The HU comes with the pins. The pin connectors connect to the pins with the female 1/8" plug spliced into it. Then you have a female 1/8" plug to plug your mp3 player into. That picture is without the adaptor, correct?
Navigation & Audio My 07 COOPER S has an mp3 jack STOCK!
surfblue
Oct 24, 2018 01:20 AM
blackie
Oct 2, 2015 07:41 PM
