Navigation & Audio Connecting BassLink II to OEM HK
Old Jul 2, 2006 | 03:44 PM
CooperCops's Avatar
CooperCops
I need some advise on the correct (best) way to connect a BassLink II sub to the HK system. TheBL II has 4 speaker level inputs (LR, RR, LF, RF). Seems to me there are 3 ways that I could do this -
1. Just use 2 inputs from the rear speakers (L & R - pins 1,2,3,4 on the HK harness).
or
2. Use 4 inputs (rear speakers L & R, - pins 1,2,3,4 AND front speakers L & R - pins 31,32,33,34).
or
3. Use 4 inputs (rear speakers L & R - pins 1,2,3,4 AND pins 22,23,24,25). These pins are for the dual coil rear speaker.
Advantages of using 4 channels instead of two (option 1)?
Advantages of using all connections to the rear speaker vs 2 channels from rear and 2 channels from front (options 2 & 3)?
In any event, I'll be making the connections to the harness at the HK amp, so ease of installation is not a consideration. Just looking for the best results.
Old Jul 2, 2006 | 08:48 PM
chikmagnet's Avatar
chikmagnet
if you only use two of the hi level speaker inputs on the basslinkII you will only get half power
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
Branto
Aug 11, 2017 05:32 PM
ROCNDAV
Oct 20, 2015 01:08 PM
blackie
Oct 2, 2015 07:41 PM
FLYM1N1
Aug 16, 2015 01:15 PM
