Navigation & Audio Could this really be the XM / BlitzSafe's fault?
Old May 30, 2006 | 10:56 AM
SweetTea's Avatar
SweetTea
Dealer A installed XM / BlitzSafe solution. At first, no sound would come out of one channel, so Dealer A instructed me to return the XM Unit to the vendor (myradiostore) and get a new one.
New XM Unit arrives, Dealer A installs. No problems for the first 3,500 miles. (Brand new 2006 MSC.)
Now, nearly all interior electronics are not working: seat belt light, sunroof, interior turn signal indicator, all radio, etc.
Go to Dealer B (much closer to my home). Dealer B claims the issue is with the XM / BlitzSafe unit, but will not plug it into a different vehicle to verify that the issue is in fact with the aftermarket unit and not, say, the internal wiring in the car. To put more salt in the wound, Dealer B claims they spent eight hours isolating the issue to the aftermarket unit (why it took them that long, I have no idea) and the warranty only covers six. So they are asking me to write a check for $94 / hour for the extra two hours. Even though I had a dealer (Dealer A) do the installation. Now I am going back and forth between the two dealers, trying to get Dealer A to either cover the two extra hours or split them with me 50 / 50.
Has anyone had any issues like this with their XM / BlitzSafe unit? Without Dealer B actually plugging in the aftermarket unit into a different vehicle, how do I know for sure that this electrical issue is not part of my vehicle itself?
Old May 30, 2006 | 11:24 AM
Krut's Avatar
Krut
That blows Steve - I would call Blitzsafe directly and speak to their reps. I've never heard of a Blitzsafe adapter causing problems like that. If Dealer A plugged and unplugged stuff with the ignition in the on position and the radio on it's possible it may have shorted something however I seriously doubt it.
Old May 30, 2006 | 11:36 AM
gadgeTT's Avatar
gadgeTT
My XMDirect/Blitzsafe unit has been fully-functional without issue since last October which is when I installed it myself. Personally, I can't see how that would have anyting to do with your car's other issues as the ONLY point it connects to your car's wiring is via the CD changer cable.
Old May 30, 2006 | 11:58 AM
SweetTea's Avatar
SweetTea
Well, Dealer B claims it must be the aftermarket unit ... as soon as they unplug it, all of the other interior electrical problems go away.
That being said, until the aftermarket unit is plugged in to a different vehicle, I don't see how one can claim it is the unit, versus the vehicle.
Old May 30, 2006 | 12:46 PM
mikeythemini's Avatar
mikeythemini
Any device that is plugged into the ibus on the mini can cause these problems if it goes wrong - some early icelink plus's caused this exact problem. Although I have never heard of a blitzsafe doing though
Old May 30, 2006 | 12:48 PM
pjschaffer's Avatar
pjschaffer
Since the Blitzsafe communicates over a data bus to the head unit, it is certainly possible that it could be sending random codes that are causing your problems. If everything works without a hitch when you unplug the blitzsafe, then the dealer is right and that's where your problem is. As the saying goes "If it looks like a duck, sounds like a duck and smell like a duck; then it must be a duck"
Old May 30, 2006 | 01:17 PM
coolcab's Avatar
coolcab
I have the XM/Blizsafe direct and have had zero problems. But I do not have a sperate XM receiver. I did the install myself...
Pker
Apr 11, 2017 12:14 AM
jetmechinnc
Nov 18, 2015 08:54 PM
pglgp1292
Oct 5, 2015 06:47 PM
waygookin
R55 :: Clubman Talk (2008+)
19
Sep 28, 2015 02:10 PM
PSU 98
Sep 11, 2015 11:20 AM
