Navigation & Audio Physical dimensions of HU and ...
Old May 11, 2005 | 12:06 PM
dmeyer's Avatar
dmeyer
Hey all,
I am planning an install in a Mini that is en route. The factory H.U. looks likely larger than normal 1 DIN. Can anyone give me the physical dimensions of the stock (non HK) headunit? Ideally also the dimesions of at least the face of the HU, AC control module, and Toggle Row, as well as the center pillar space in all. I am trying to determine how much space I can make in the center pillar for a touchscreen LCD. :smile:
Old May 11, 2005 | 12:46 PM
blalor's Avatar
blalor
You might want to check out Crutchfield's website. They'll be able to tell you what will fit, and from that you can probably determine the size of other head units...
Old May 11, 2005 | 12:52 PM
dmeyer's Avatar
dmeyer
Unfortunately they don't have the mini in their system...
Old May 11, 2005 | 01:27 PM
mbabischkin's Avatar
mbabischkin
Funny, I found the MINI in there...
Old May 11, 2005 | 02:01 PM
dmeyer's Avatar
dmeyer
Its in there, but when i select 2005 Hatch with Nav it shows no matches. In any case that wouldn't give me the measurements of the other pieces
Old May 12, 2005 | 07:38 PM
Americonium's Avatar
Americonium
I'm going to make a very educated guess and say single din head unit will fit perfectly......
However, if you got the Nav system, then I'm not sure how that would interface for audio with an aftermarket head unit.
Old May 13, 2005 | 10:54 AM
blalor's Avatar
blalor
They do for '05s. I just checked. :-)
Old May 13, 2005 | 10:55 AM
blalor's Avatar
blalor
... and I would have seen the replies, if I could just suppress the urge to post first...
Old May 13, 2005 | 11:15 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Hey all,
To get the pillar measurements just go to the dealership and measure what you need.
The stock HU measures-
7.25" wide, 2 1/8" tall, 6.25" deep
Face plate outer dimensions are-
7.5" wide and 2 7/8" tall with mounting brackets out to 8 5/8" on the lower end and three sets of holes. The top set of holes is 7 7/8" from center to center and the lower two sets of holes are about 8" from center to center.
I replaced my stock HU with a Nakamichi CD400 that fit fine. I had an aftermarket face trim plate installed.
Old May 14, 2005 | 05:07 AM
dcsmd007's Avatar
dcsmd007
Coordinator :: PDX MINI
The OEM unit is a typical single-din design. I installed Kenwood KVT-815 DVD/GPS monitor HU without any modification. There's quite a bit of space behind the stereo and AC control panel to house a unit with longer dimension. :smile:
Doc Pain
Mar 10, 2021 04:50 AM
minimofo
Dec 26, 2015 12:03 PM
pkillur
Sep 30, 2015 10:51 AM
Capt_bj
Sep 29, 2015 04:22 PM
///Matthew
Sep 15, 2015 03:45 AM
