Navigation & Audio Radio ‘Disabled’
Old Aug 17, 2019 | 02:34 PM
jpmcc00's Avatar
jpmcc00
Radio ‘Disabled’
I have a problem with my Boost Radio fitted to R52
Had the battery disconnected for a short time and now the radio is showing as disabled.
I have disconnected the battery again, joined terminals together, left the car overnight.
Had the radio out and reseated the plug again, checked all fuses and still getting the error messages.
There is no option to enter a code and I’m stumped.
Anyone come across similar before?
Standard boost radio which is original to the car and no CD Changer fitted
Old Aug 17, 2019 | 02:52 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Did you look at the bottom of the thread for related topics? I see 5 threads showing.
Old Aug 17, 2019 | 03:17 PM
jpmcc00's Avatar
jpmcc00
Yes, I’ve read most of the threads on here and many on google.
A lot point to cd changer of which I do not have, I’m struggling to find an explanation as nothing has been changed or added other than the batter being disconnected.
Old Aug 21, 2019 | 03:16 PM
jpmcc00's Avatar
jpmcc00
Still looking for a solution.
Any ideas...
Old Aug 23, 2019 | 12:17 PM
A383Wing's Avatar
A383Wing
I'm guessing here that you have installed a different radio into your car?
What year is the car?
What year is the radio?
You have basically given us nothing to go on.....
Bryan
Old Aug 25, 2019 | 03:22 PM
jpmcc00's Avatar
jpmcc00
Bryan
No, disconnected the battery and now the original radio is ‘disabled’
2006 - R52
Boost Radio
Original Radio that came with the car..
Old Aug 25, 2019 | 03:35 PM
A383Wing's Avatar
A383Wing
One of two possibilities, either turn your key on, and walk away from the car for a while, maybe 30-45 minutes, or, you might have a K-bus wire issue under the passenger front seat like my '06 R52 had
Bryan
Old Aug 25, 2019 | 03:50 PM
jpmcc00's Avatar
jpmcc00
This is very helpful thank you.
I have tried the key in and walk away already.
But Passenger seat was removed when the battery was disconnected. I’m wondering if wiring below that has now been disturbed?
Is is obvious to see the KBUS wiring or does some of the carpet need removed?
Bryan
Old Aug 26, 2019 | 12:40 PM
A383Wing's Avatar
A383Wing
If your passenger seat is already out, remove the side plastic trim panel at the door opening, pull the carpet up from the side and look at your K-bus wiring under there....the pictures I posted were what I found when I pulled my carpet up. Plus it was very wet under there, took about a week to dry it all out with a 20" box fan
Bryan
badalo4
22
Jan 27, 2019 07:59 PM
LizDew
Jun 12, 2011 06:20 PM
ReginaK
Mar 11, 2011 05:01 AM
pappde
Jul 28, 2008 08:37 AM
