Navigation & Audio Finalized my Project!
Old Sep 10, 2019 | 03:55 PM
  #26
varma1986's Avatar
varma1986
I want to change the iDrive controller for my 2018 MINI COOPER COUNTRYMAN F60. Can U advice me the steps to remove the trim to reach the part and swap it for the new one?.
Old Sep 11, 2019 | 06:22 PM
  #27
6FT6's Avatar
6FT6
The trim around the controller and shifter pops right off and you will see screws holding down the controller. Unscrew, disconnect, remove old controller and put the touch idrive in and screw down. It’s a very simple process.
Old Sep 11, 2019 | 06:23 PM
  #28
6FT6's Avatar
6FT6
Will the Controller # 6582-9332-289 work with 2018 MINI COOPER COUNTRYMAN F60?.
Yes.
Old Sep 11, 2019 | 11:25 PM
  #29
minicooperjp's Avatar
minicooperjp
Originally Posted by 6FT6
@minicooperjp does your retrofit head unit show animations and images of an F56 or an F60? I got my retrofit done but the images are all F60.
F60 for me but probably due to the software, since I got this done when the 2019 F56 I step level was probably not there yet.
Old Sep 12, 2019 | 08:03 AM
  #30
6FT6's Avatar
6FT6
Yea, I'm realising that a lot of F56 owners that did the swap have incorrect animations and no manual, so far I only know of two people that had that rectified through coding (sb2002 being one of them).
@minicooperjp Did you ever get the 8.8" touchscreen sold?
Old Sep 12, 2019 | 02:19 PM
  #31
varma1986's Avatar
varma1986
Thank You.
Old Sep 12, 2019 | 02:21 PM
  #32
varma1986's Avatar
varma1986
I have installed an aftermarket tailgate & Kick sensor on my 2018 MINI COUNTRYMAN F60.Is there a way that i can code the Mini cooper to recognize this aftermarket tailgate on the central display?.I know the topic is different...but please if U can advice...Thank You.
Old Sep 12, 2019 | 02:32 PM
  #33
6FT6's Avatar
6FT6
No, you’re on your own with aftermarket unless you wired directly into the stock controller.
Old Sep 14, 2019 | 10:49 PM
  #34
minicooperjp
Unfortunately I did sell a while back
Old Sep 15, 2019 | 10:15 AM
  #35
varma1986's Avatar
varma1986
I have a 6.5" screen and i am able to get Wireless CarPlay via the "JoyeAuto NBT Evo BMW Interface Kit" connected in a Plug & Play with my 2018 MINI Cooper CountryMan F60.
I purchased the kit from aliexpress website.
https://www.aliexpress.com/item/3305...45524c4dJKktFm
Hope the info helps.The touchscreen on the Car play & Interface kit however does not work.
I used an "aux-USB adapter" to connect the Interface kit> to plug back into the main USB port on the dash >to output sound.
Old Sep 15, 2019 | 10:26 AM
  #36
varma1986's Avatar
varma1986
I plan to swap my 2 directional joystick idrive controller for the fancy JCW 4 directional idrive controller...would i require any coding?.
https://www.ebay.com/itm/MINI-F55-F5...4/333315607199
^my old part.
https://www.ebay.com/itm/BMW-MINI-CO...72.m2749.l2649
^my new part.
idrive part # 63176949(basic) to idrive part#9332289 is the project i have in hand and the JCW fancy part#9332289 is in transit currently.
Will adding the idrive unlock new features on the main console?.
Can someone help?. Thank You.
Old Sep 16, 2019 | 09:12 AM
  #37
6FT6's Avatar
6FT6
^my old part.
^my new part.
No coding needed if you just want to use the joystick and the radio/menu/option buttons. It will need coding if you want to use touch/writing and you will need to get the touchbox/TBX module.
Old Sep 16, 2019 | 01:15 PM
  #38
varma1986's Avatar
varma1986
Thank You.
Old Sep 16, 2019 | 01:16 PM
  #39
varma1986's Avatar
varma1986
thank you.
Old Sep 16, 2019 | 04:35 PM
  #40
6FT6's Avatar
6FT6
https://www.youtube.com/watch?v=qIesmEMCW5A
https://www.youtube.com/watch?v=q8kCd4ET8-k
Not my cup of tea but it’s great you got something to work to your satisfaction. Are hands free calls all thru the car mic/speakers? That audio thru aux sucks.
Old Sep 16, 2019 | 05:37 PM
  #41
varma1986's Avatar
varma1986
The Kit has its own separate mic that you can install hidden on the upper A pillar, drivers side.
The calls are hands free & the steering wheel controls work to navigate the interface.
Sound output is through the car speakers.Apple will not allow you to use the phone while on the CarPlay.
The touchscreen does not work on the interface, and u will have to use the idrive controller or steering wheel controls to surf through the kit menu.
The kit is supposed to work with both aftermarket/oem camera but on my Kit the dip switch to enable this feature, was buggy and hence i have it on the aftermarket camera.
I also have a Raydeen BSS2LPB Blind Spot Detection system installed under the license plate and the built in camera on this module was hooked to my kit and it is as good as original with the parking sensors and all that!.
The Kit allows you to switch between the OEM & its interface with the simple long press of the back button..
You will not ordinarily notice the Aux adapter as it is lower down in the well.
Once the car is set up for Apple Car connection with the mobile phone,it will auto switch to the kit interface automatic without any intervention.
Old Sep 16, 2019 | 07:08 PM
  #42
6FT6's Avatar
6FT6
Ok cool. With OEM mini wireless CarPlay you can use the phone btw.
Old Sep 16, 2019 | 07:54 PM
  #43
varma1986's Avatar
varma1986
When the Apple Car Play is active, i was not able to use the camera app on my phone for some strange reason but otherwise all else is normal.I understand that for the OEM MINI Wireless Carplay U have to pay an approx 90 US$/year.
https://www.caranddriver.com/news/a1...an-annual-fee/
Old Sep 17, 2019 | 04:05 PM
  #44
6FT6's Avatar
6FT6
Nope not an extra cent and I’m in the US
Old Sep 18, 2019 | 02:07 PM
  #45
varma1986's Avatar
varma1986
I put the MINI decal sticker on the dial!.
I was able to do this little project.
#1-The trim around the cup holders to pull out carefully.
#2-The trim around the gear shifter to pull out carefully.
#3-The plastic assembly to be pullled upwards from the storage area.
The entire thing is held by strong clips.
#4-Two Allan chain screws to remove & the other end of the controller is held in a clip to pop out.
#5-Check your new controller by plug & play.Replace your old one with the new!.
This JCW controller gave me a 4 way joystick controller to help use on google maps & navigate better on interface on apple car play!.
Old Oct 28, 2019 | 04:09 PM
  #46
Bezlar's Avatar
Bezlar
We bought my daughter a 2016 f56 cooper s 3 door. It has the 6.5 screen no nav Harmon system. Does anyone know if it is possible to add the touch 8 screen and get car play to work? Where would I go for info and parts list. Thanks. I’m looking for a winter project. Lol
Old Oct 28, 2019 | 04:27 PM
  #47
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Did you see this thread? https://www.northamericanmotoring.co...-possible.html
Old Oct 28, 2019 | 07:00 PM
  #48
Bezlar's Avatar
Bezlar
Originally Posted by Minnie.the.Moocher
yes I did.
thanks
Old Apr 23, 2020 | 03:36 AM
  #49
fliflaflu's Avatar
fliflaflu
Parts
These parts are what I needed as I had the regular radio, if you already visual boost, which is the 6.5" display, the cost will be less and less work will be required.
Part #s and links:
Touchscreen: 65506820386
CID cable: https://www.ebay.com/itm/BMW-F10-F20...-/253205196176
NBT EVO Unit: 65128708270
Controller: 65829866934
Touch Unit: 65829371374
Emulator:https://www.ebay.com/itm/Plug-and-pl...19.m1438.l2649
USB Cable: https://www.ebay.com/itm/BMW-CIC-NBT...72.m2749.l2649
Wi-fi antenna: https://www.ecstuning.com/b-genuine-...n/61119308571/
Or
Bluetooth: https://www.ebay.com/itm/BMW-CIC-NBT...72.m2749.l2649
2nd microphone: https://www.ebay.com/itm/BMW-CIC-NBT...EAAOSw~0paRLt1
GPS antenna: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
FSC Codes: CarPlay and activation of navigation services ($250)
Create harness for audio control panel
My cost was about $2,000-$2,500
Hey there, i just bought all the needed parts but are struggeling to get everything working. You may could answer me a few questions? That would be great
Old Apr 29, 2020 | 05:24 PM
  #50
DDominick's Avatar
DDominick
I would like to do this as welt my 2015 Mini Cooper 4 door base model. wondering cost and what I need to complete
