Navigation & Audio Aux input not showing up
Old Mar 19, 2019 | 03:03 AM
  #26
m100JCW's Avatar
m100JCW
Originally Posted by Jorge Mujica
Hi has anyone find a solution for this? I have an R56 2010. changed the input, not working. Bought a used/repaired radio on ebay and everything works except the AUX in. tried wiring straight from the back radio connector straight to the new wire and still not working. Thanks !!!!!!!!
PS: Tried connecting my Iphone and PC into the aux. none of them worked.
​​​​​​Not sure if it's the same with the R56 but in an R53 the cable needs to have a 300Kohm resistor between left and right...this resistance is what tells the head unit the cable is plugged in. So check this first if you have a multimeter handy
You may also want/need to put in place a couple of capacitors to remove any ground offset between your aux input device and your head unit.
Have a Google for BMW input cable DIY for more info
I know this as I installed a "plug and play" Bluetooth adapter into my car last week...this needed the resistor in order to work..but didn't need the capacitors as it shared the same ground as the head unit. Can't complain as it was less than $10 including postage.
Old Mar 19, 2019 | 07:13 AM
  #27
jsthomas00's Avatar
jsthomas00
This explains why the noise filter I put in place works as well.
Old Jun 28, 2022 | 01:16 PM
  #28
USNAE2's Avatar
USNAE2
Veteran: Navy
I know this an old thread. However, I have this same issue, my AUX does not show up anymore on my display. It doesn't show for AUX VOL either when pressing the music note for adjustments. It has worked flawlessly for the 7 years I have owned the car (was already in place when purchased). I have replaced the head unit once for a CD error problem and after worked. I am an Journeyman Aircraft Electrician and until just recently worked in microelectronics so none of the wiring is difficult for me. I did recently replace the H/K amp due to a LOUD static interference issue. That fixed that... however after about a couple of weeks it happened. I disconnected the Bluetooth attached to it and reseated and it worked again but a few days ago happened again. No amount of reseating seems to be helping. After reading the above posts, I may disconnect charging to the Bluetooth to see if that helps but, I have had it in this config for a couple of years and it never was an issue. I was wondering if the AUX is strictly a function of the head unit and has nothing to do with the amp (which would be weird).
I guess it's possible that the main connector in the back of the head unit is loose or has come loose (haven't checked yet)? Is there a possibility that it can actually be the head unit itself as the issue?
I am trying to keep the oem look of the main instrument pillar section but, IF I was to get a new head unit that will work with the H/K amp; what would that be?
Old Jun 29, 2022 | 03:11 PM
  #29
USNAE2's Avatar
USNAE2
Veteran: Navy
I figured out the problem. The MPOW Bluetooth Receiver has just slightly unplugged from the cord...not 'snapped' in. All good now.
ReMaxguy
May 23, 2012 08:57 PM
MrCooperS
20
Feb 10, 2009 10:51 PM
droptopmini
Jan 22, 2008 03:57 PM
Toby Weir-Jones
Jan 26, 2006 06:36 AM
ripley
Sep 24, 2005 05:41 PM
