Navigation & Audio aux input problem...
Old Apr 21, 2006 | 12:29 PM
ReMaxguy's Avatar
ReMaxguy
dealer put in my aux input...
worked fine with ipod or my ps2 install... on navi screen...
today.. when i use mode button to turn it to aux, it plays for a minute and switches to radio.... i tried looking for aux again, didn't work...
need to pull the aux cable out and plug it back it for it to turn on for a sec or two again...
then it goes back to radio again...
i don't know whats going on... did anyone had that problem?
Old Apr 21, 2006 | 12:46 PM
The MINITOR's Avatar
The MINITOR
Sounds like a common problem with an easy solution. You need a ground loop isolator, available at Radio Shack for about $16 I think. Use the search function here on NAM and you will find more info.
Old Apr 21, 2006 | 12:50 PM
Motor On's Avatar
Motor On
+1
Old Oct 4, 2009 | 08:54 PM
starkey421's Avatar
starkey421
So I just bought a 2006 MCS and it has nav and the HK stereo. I just installed a aux input which was taken from a 2008 model it has three wires a yellow black and clear. I saw a post on which pins to connect them to and to move my nav voice to the same connection and it worked... PROBLEM... I am only getting the vocals from the passenger side. Mid range and bass are working but not vocal. It works perfect with a cd mp3 and the radio but not with the aux.... Any suggestions?
Old May 23, 2012 | 08:57 PM
robertflowers12's Avatar
robertflowers12
aux speedometer display problem
Hello,
I have a 2008 Mini Clubman S. The dealer I bought the car from replaced the speedometer. The problem is that my car was setup for an aux input and the speedometer shows USB in the menu. I'm unable to select aux. Can the speedometer be reprogrammed? Any help would be appreciated.
Thank you.
[FONT=Calibri][SIZE=3] [/SIZE][/FONT]
rikaro
Nov 24, 2015 02:05 PM
eliseo1981
Nov 2, 2015 11:24 AM
Levers_and_Gears
Sep 28, 2015 04:42 PM
BossyR56
Sep 28, 2015 11:33 AM
