Navigation & Audio Garmin GPS Install please help!
Old Dec 6, 2013 | 08:27 PM
BC_Rob's Avatar
BC_Rob
Hi Everyone,
I just received my Garmin GPS Mini Navigation Installation Kit but the only installation instructions available online show a four-wire harness and mine has a simple two-wire.
I'd like to install myself but don't know where to tap in for power. Any thoughts?
Rob
Old Dec 6, 2013 | 08:33 PM
vetsvette's Avatar
vetsvette
Moderator
Cigarette lighter power under the console. I just use the lighter adaptor and routed the wire between the console and lower kick panel with the wire coming out beside the tach.
Old Dec 6, 2013 | 08:46 PM
BC_Rob's Avatar
BC_Rob
'Lighter Adapter', does that mean I need to purchase it or is the adapter just waiting for me to find it?
Rob
Old Dec 6, 2013 | 08:56 PM
vetsvette's Avatar
vetsvette
Moderator
Old Dec 6, 2013 | 09:02 PM
BC_Rob's Avatar
BC_Rob
Got it. I thought you meant tapping into the cigarette lighter circuit (from below so that it's unseen) and hardwiring that way. I have a wiring harness that I'd like to use but I don't know where to tap for power so that it is a clean install. It really should be a simple power tap as I have a positive and negative two-wire harness just waiting to connect
Rob
I use a Garmin power cable that has the adaptor that just plugs into the cigarette lighter. I have since acquired an adaptor that has two USB power outputs and I'll just use the Garmin USB cable for the GPS and use the other port to charge my phone.
Amazon.com: Garmin 10-24V - 2amp Vehicle Power Cable: Electronics
Amazon.com: Dual USB Car Charger 3.1Amp 15.5W - 1.0&2.1A Universal Ports, Smart Power Supply For iPods, iPhones, Cell Phones & Tablet, Android Devices, Portable Cigarette Lighter Plug, Mobile Travel Charging Station 12V Input: Electronics
Old Dec 6, 2013 | 10:38 PM
vetsvette's Avatar
vetsvette
Moderator
Like I said in post #2. Tap into the wires for the cigarette lighter under the console, using your two wire kit. It is switched power.
Old Dec 7, 2013 | 05:25 AM
jcauseyfd's Avatar
jcauseyfd
You could wire it over to the fuse panel. That's what I did when I hardwired my GPS. Got an add-a-fuse or some thing like that to create an additional spot.
Old Dec 7, 2013 | 02:52 PM
BC_Rob's Avatar
BC_Rob
Okay, install is complete- looks and works great.
Thanks for your help!
Rob
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
milkrun49
Factory JCW Talk (2009+)
Aug 13, 2015 06:01 AM
