Navigation & Audio Preparation BMW satellite radio
Old Oct 15, 2013 | 07:51 AM
RockAZ's Avatar
RockAZ
When I used the VIN decoder I got this line on the build sheet : " Preparation BMW satellite radio ". Now, what exactly, does that mean? Did my Mini originally have Sat radio but the previous owner let the subscription lapse? And that is why it no longer shows it as an option on the "Audio" button menu? And, what must I do to get it back, I assume it is Sirrus,....
Thanks for any input.
Old Oct 15, 2013 | 07:53 AM
RockAZ's Avatar
RockAZ
Oh, found this enlightening thread when I used different search terms. Hmm, seems a little expensive....
https://www.northamericanmotoring.co...eparation.html
Old Oct 15, 2013 | 08:04 AM
cerenkov's Avatar
cerenkov
In the next few days I'm going use NCS Expert to change my vehicle order code to hopefully enable this. I'll update this thread to let you know if it worked or not.
Old Oct 15, 2013 | 08:15 AM
MINILLA's Avatar
MINILLA
Yep my dealer quoted me $500...........go figure...I went the accessory route and installed the XM Onyx...works well looks good....especially since it was $450 cheaper....
Old Oct 15, 2013 | 12:16 PM
RockAZ's Avatar
RockAZ
So basically the Onyx plugs into the back of the stock Mini radio?
Old Oct 15, 2013 | 05:34 PM
MINILLA's Avatar
MINILLA
It plugs into the auxiliary socket (if you have one) I'll post a pic tomorrow if I can get to the car before my wife leaves for work.
Old Oct 17, 2013 | 09:04 AM
MINILLA's Avatar
MINILLA
XM Install
XM1 picture is taken from the driver seat. The radio is attached to a mount that sits in the passenger side cup holder. No attachments other than a pressure fit holds is in place.
XM2 is from the passenger side and you can see the leads/cables are all enclosde in one black wrap. The aux in socket is down under the dash alongside the USB drive. This was the arrangement in my 2010 Clubman as well as what is in my 2013 Cooper Hardtop. The antenna cable is threaded through under the dash/glove box area...under the door seal and along the leading edge of the dash top. It sits on the dash as far forward as it can.
The whole system works well especially when compared to the $500 cost of enabling the system that MINI are charging.
Attached Thumbnails Preparation BMW satellite radio-xm1.jpg   Preparation BMW satellite radio-xm2.jpg
Old Oct 20, 2013 | 03:47 AM
richardsperry's Avatar
richardsperry
Why not just use the Sat/Nav antenna already in the car? All MINI's have one. THe terminal end is tucked into the space under the passenger seat where the SAT radio module goes. All you need a extender cable...
Old Oct 20, 2013 | 04:36 AM
MINILLA's Avatar
MINILLA
Originally Posted by richardsperry
why not just use the sat/nav antenna already in the car? All mini's have one. The terminal end is tucked into the space under the passenger seat where the sat radio module goes. All you need a extender cable...
not!...I have the extender cable...I used it in my 2010 Clubman...the question was about the 2013....I can't find it under the seat of my 2013....I was asking if anyone knew if it was still pre-wired and where the terminal was.....your answer is way to simplistic...makes a number of assumptions without helping in any way.
Old Oct 20, 2013 | 08:59 AM
richardsperry
Did you take the cover off the compartment and look under the Styrofoam?
embiggenedmini
Oct 15, 2015 12:36 PM
SneedSpeed
Sep 2, 2015 05:34 AM
Zettinger
Aug 25, 2015 04:04 PM
Shane Wendel
Aug 18, 2015 01:13 PM
veevsato
Aug 5, 2015 04:42 AM
