Navigation & Audio stock HU wire for remote turn-on for external sub or amp?
Trying to find is there a remote turn-on on factory HU (boost) for external amp or sub? Tried searching for 2 days now, can't find anything.
If there's no remote on HU, ho do you guys do it then? from ACC in key? any good place to splice the wire before I disassemble half of the car searching for one?
I'm trying to hook up Infinity powered sub in the trunk. I'll get main power from battery (I got S, it's in trunk), use speaker level inputs either from rear speakers or using PAC OEM2.
Any help would be appreciated.
Thanks!
Thanks!
It's your system, but I think you'd be better off using the power antenna wire. That way the head unit is powered on before the amp. If the amp gets power before or at the same time as the head unit, you might get a "pop" sound in your speakers when you turn the key.
Originally Posted by scooterboy
There's no dedicated remote turn-on wire, but you can tap into the power antenna wire instead (white wire in harness).
1. Tap wire in dash for this purpose.
2. Run remote/fan power wire through switch in "Euro Parcel Shelf".
3. From Switch to fans/remote amp connector.
Result: I can have Bass and a "cool" amp when I want it, not all the time.
Thanks for any feedback,
Chad
whenever i hear bout the pros doing stereo installs, they always use a switched power lead form somewhere besides the HU.
i never use the HU's remote power wire, i always use my own
Thanks,
Chad
pull from a switched power lead in the fuse box or pull directly from the battery, (or run a jumper from the power on the amp to a switch in the front of the car on the dash and back to the remote turn on....there are a few ways to do it.
if you need any more help , gimme a hollar, i just got dont doing all of my stereo stuff
Dec 23, 2015 10:36 AM
skippermini
Aug 13, 2015 06:13 AM
