Navigation & Audio Radio Replacement
Old Jan 31, 2013 | 11:41 AM
demariai's Avatar
demariai
Radio Replacement
Hey guys, Im thinking to replace my factory radio on my mini 2006 base with out Nav. I want to still be able to use controls on the steering wheel and not spend a lot of money.
Im looking at this radio:
http://www.crutchfield.com/p_105KDR7...KD-R740BT.html
and I was told I'll need this harness to be able to control it from the steering wheel:
http://www.crutchfield.com/p_541SWIR...SWIRC&skipvs=T
Do you guys have a better option?
Please let me know
Thanks!!
Old Jan 31, 2013 | 12:19 PM
Eric_Rowland's Avatar
Eric_Rowland
What are you looking for from a head unit that you're not getting from the OEM unit? Without knowing that info, hard for anyone to comment whether the one you're looking at will meet your needs.
Also, you might want to post this (or have it moved) to the Nav and Audio forum.
Old Jan 31, 2013 | 12:22 PM
demariai's Avatar
demariai
I just want to add blue tooth to my mini and I was told a new radio will sound a bit better
How can I move this to the audio forum?
Thanks!
Old Jan 31, 2013 | 12:34 PM
Eric_Rowland
Bluetooth is definitely something that would require a different unit. The OEM solution costs a fortune, and isn't widely available.
To move a thread, hit the red triangle by your first post, then in the comment box ask them to move it to the appropriate forum. Good luck!
Old Jan 31, 2013 | 12:50 PM
demariai's Avatar
demariai
done, thank you!
Old Jan 31, 2013 | 06:04 PM
ViperNL's Avatar
ViperNL
For bluetooth, also check this out: https://www.northamericanmotoring.co...tooth-kit.html
Old Jan 31, 2013 | 09:23 PM
InjectedGT's Avatar
InjectedGT
If you want an upgraded head unit with built in blue-tooth, I would up the budget a bit. JVC's entry level stuff, in that price range, is good for what it is: Entry level upgrade with minimal features. Once you toss in features like bluetooth at that price range, you sacrifice quality.
I would look into a Kenwood Excelon(And only the Excelon line) for a unit with bluetooth(Kenwood's is built in, not a separate unit like Alpine and some others con you into), that also has the features you want.
You might end up spending more than $130, but also consider it is the source of all your sound, it is the main point of contact between you and your music. It's a very important part of the system to focus on.
StillK
R55 :: Clubman Talk (2008+)
Dec 7, 2022 08:19 AM
Zettinger
Aug 25, 2015 04:04 PM
Shane Wendel
Aug 18, 2015 01:13 PM
Herleman
Aug 16, 2015 06:41 PM
veevsato
Aug 5, 2015 04:42 AM
