Navigation & Audio ipod use with a stock radio
Hello everyone,
I just bought my first mini last week. It's a 2002 base model, which has a stock radio with a single CD player. I am not familiar with mini and after reading about some products to adapt my radio to use my ipod, I am completely confused. I do not want to replace the stock radio, just listen to my ipod through it. Please help, thanks.
Models prior to January 2003 do not have an AUX jack on the back of the stereo, so there is no provision to add the AUX adapter (which is a 3.5mm jack). You can opt to replace the stereo with a later model. You should be able to find one in the FS section here or on E-Bay for $50 or so. The only other option is to get an FM broadcaster that plugs into the lighter/auxilary power socket. Results with them are hit-and-miss.
If you're gonna go with buying a new head unit, might as well make the effort and buy one from 04-06, those ones can play MP3 cds. Easy way to tell is the volume ****– yours looks like a pencil eraser, the ones you want have a much larger volume ****.
Plug and play. Center stack never changed in all years of the R50/53.
OK, so I am searching for a new head unit from 04-06, that plays MP3 cds, and has the larger volume ****, rather than mine that looks like a pencil eraser. The problem is they all say that they will not fit 2002 minis. Is this true? Any ideas?
That's not true. All 1st-gen MINI head units are interchangeable. They all use a quick-release wiring harness. The two AUX and CD changer leads plug in "through" a blank area of the harness after it's mounted.
I have an extra head unit with MP3 capability. $50 if you are interested. I also have the MP3 CD changer. I bought it brand new off E-Bay last year for $330. $200 and it's yours. Or you can opt for a regular CD changer (non-MP3); that's $50. Plus shipping (should not be too much).
So you know what's involved, each one of the stereo pillars has two torx-bit screws that have to be removed. To get to the ones on the driver's side, you have to drop the panel below the steering wheel. That requires using a long screwdriver and pressing down in the gap underneath. Once the screws are removed, just slide the pillars left-and-right. You then need a phillips head screwdriver to remove the four screws from the front faceplate. There is a rubber (or nylon) screw that has to be removed from the post to get the wiring harness/loom off the back of the unit.
OP I'm where you are at, I have been doing extensive research on this, here are the plug and play options I have found:
Dice Silverline Duo:
http://diceelectronics.com/duo-ipod-sirius
Dice Media Bridge + bluetooth:
http://diceelectronics.com/media-bridge-info
USA Spec:
http://usaspec.com/product.php?ProductID=18
GTA Car Kit:
http://www.gtacarkits.com/mini_coope...06_car_kit.php
Neo Prolink:
http://www.neocaraudio.com/cars/2006_MINI_COOPER
I'm debating between the Neo Prolink and the Dice Media Bridge since they both have bluetooth for phone calls which I think will be great.
I've had nothing but excellent success with USA Spec
USA Spec:
GTA Car Kit:
Neo Prolink:
As others have said, it's all plug and play, I replaced a friend's '02 unit with a later model and added the aux-in.
Navigation & Audio iPhone5 / Lightning adapter for OEM ipod interface
ROCNDAV
Oct 20, 2015 01:08 PM
