Navigation & Audio Saving sound quality setings
Old Apr 21, 2012 | 07:40 AM
Grovedale's Avatar
Grovedale
Hello, I have a 2007 Cooper S, with the boost CD and factory ipod in put. I go to the music note button to adjust bass, treble, balance etc, make the adjustments I want and let the system return to the home screen. When I get into the car next time the settings I adjusted always return to the way they were before I adjusted them, ie "0" what am I doing wrong?
Old Apr 22, 2012 | 08:44 AM
Grovedale's Avatar
Grovedale
Bump, still looking for an answer.
Old Apr 23, 2012 | 08:12 AM
schatzy62's Avatar
schatzy62
Dont let the system return by itself force it to close by the buttons.
I can not confirm this on a 2007 but on the 2008 and up each input has its own settings so if you set the iPod input and then come back to the car and the radio is on they will be different. You would have to change to the iPod input then press the note button to see the settigns for the iPod input.
Old Apr 23, 2012 | 10:11 AM
Grovedale's Avatar
Grovedale
Thanks for the reply, so all I do is make the adjustments, and press the note button to save?
Old Apr 23, 2012 | 11:38 AM
schatzy62's Avatar
schatzy62
Yes that should do it. Let me know if you have any other problems.
Old Apr 23, 2012 | 11:50 AM
Grovedale's Avatar
Grovedale
Thanks again, will try it right now.
Old Apr 26, 2012 | 04:48 AM
schatzy62's Avatar
schatzy62
did you get your problem resolved?
Old Apr 26, 2012 | 05:23 AM
Grovedale's Avatar
Grovedale
No, that did not work. I did as you suggested, made the adjustments, both for cd player and ipod. Then I closed by pressing the music note button, when I came out later and restarted the Mini, same thing, all preset sound adjustments had returned to "0". I'm confused, or my radio unit might be defective.
wildwestrider
Sep 4, 2015 06:25 AM
Aug 25, 2015 09:28 AM
makg
Aug 21, 2015 02:49 AM
dpcompt
Aug 12, 2015 07:39 PM
MiniJess
Aug 10, 2015 09:51 PM
