Navigation & Audio HD Radio help
Old Oct 20, 2011 | 04:32 AM
Subzero's Avatar
Subzero
HD Radio help
Greetings! Have a question about HD radio in my 2012 S. My regular car manual says to reference the separate manual for the HK system, but said manual didn't come with the pack of other booklets that were in the glove compartment.
The only radio station I listen to is The Ticket in Dallas. They broadcast on 1310 AM and 104.1 FM. They are also apparently on 99.5 "HD2". When I tune to 99.5, it locks in the FM, then immediately jumps to HD1. I'm assuming there is a way to force the radio to search for HD2, but nothing I've tried works, and like I said I have no radio manual.
Any ideas? Thanks!!
Old Oct 20, 2011 | 07:05 AM
schatzy62's Avatar
schatzy62
You will need to get this manual from the dealer. Tell them it is missing and you need it.
The 2008 manual is of not help i just looked at it and it does not say anything about how to change from HD1 to HD2.
Have you tried just pressing the HD button again to see if that changes it. when you press the FM button it will change from FM to FM 2.
Old Oct 20, 2011 | 07:17 AM
tccox's Avatar
tccox
I'm not in my car right now but me thinks,,,,, you hit inf button then rotate right **** to select HD1 or HD2.
Old Oct 20, 2011 | 07:36 AM
Subzero's Avatar
Subzero
Sweet, thanks for the replies. I went and tried it again, when you are on the FM station, hit the 'list' button and then you can rotate down to HD2.
On a somewhat related stereo question, I'm pretty sure there is a way to increase the AUX-IN volume, but that isn't too obvious either. I haven't even messed with my AUX yet, but thought I'd ask while I was here. I'll be sure to ask the dealer about the manual.
I'm a music nut, but I'm finding that the exhaust note is more fun to listen to! Thanks!
Old Oct 20, 2011 | 01:19 PM
PezRadar's Avatar
PezRadar
The Ticket - Good choice.
Old Oct 21, 2011 | 06:18 AM
Subzero's Avatar
Subzero
Heck yea, P1 all the way, baby!
I solved the aux-in volume question. The same button you use to select the "HD2" becomes the aux-in volume selector when aux is set as the current source. Hope that helps someone else!
Thanks all!
Old Oct 21, 2011 | 08:27 AM
strobeyprobey's Avatar
strobeyprobey
Also to select HD2 you can press the right arrow button.
bahman
Feb 14, 2016 10:29 AM
pglgp1292
Oct 5, 2015 06:47 PM
ahorvath
Oct 3, 2015 01:13 AM
simo711
Oct 1, 2015 05:36 AM
