Navigation & Audio sterio not working
Old Jan 22, 2010 | 06:21 AM
OH REALLY's Avatar
OH REALLY
sterio not working
i took my mini 07 to best buy and had them install a box and amp in the car...and now my stereo will not turn on they said they have no idea why and want me to take it back to the dealer to have it fixed...
Will this void my warranty and what could be the problem?
PS i checked all the fuses...
Old Jan 22, 2010 | 11:36 AM
OH REALLY's Avatar
OH REALLY
bump
Old Jan 22, 2010 | 11:57 AM
daflake's Avatar
daflake
No MINI will not warranty external work. Best Buy is known to do stuff like this as they are far from professionals in that area. It sounds to me like you need to have Best Buy step up and fix this. Good luck...
Old Jan 22, 2010 | 12:32 PM
schatzy62's Avatar
schatzy62
I would make sure that Best Buy take out he equipment they put in and then if the radio works find another place to go have the stuff installed.
If the radio still does not work then make sure that you get in writing they will pay for the repair if it is not covered under warranty.
Now with all that said if the dealer sees any and I mean ANY signs for work being done on the stereo system or its wiring then they will not cover the repair, and you will have to pay going rates to get it fixed.
Good Luck!
Old Jan 25, 2010 | 06:57 AM
OH REALLY's Avatar
OH REALLY
yup bestg buy is going to pay for this... just started a case number today and had made an appointment at the mini dealership...
Old Jan 25, 2010 | 07:22 AM
schatzy62's Avatar
schatzy62
Good luck with getting it straightened out.
Old Jan 25, 2010 | 07:28 AM
OH REALLY's Avatar
OH REALLY
thanks
Old Jan 25, 2010 | 09:03 AM
rkw's Avatar
rkw
Most likely, the dealer will simply put the stereo back to the original configuration and ensure that it works. Then you'll be on your own again as far as getting the sub and amp to work.
Old Jan 25, 2010 | 10:44 AM
OH REALLY's Avatar
OH REALLY
funny thing is all the amp wires were disconected already and the sterio still wount power up
Old Jan 25, 2010 | 03:22 PM
miniSQ's Avatar
miniSQ
this was a problem another guy had a couple months ago, a faily long thread...but you will have to search for it....
Long story short... there was a fuse behind the HU that blew.
Old Jan 26, 2010 | 08:42 AM
OH REALLY's Avatar
OH REALLY
thanks for the help but what is a HU?
Old Jan 26, 2010 | 08:53 AM
schatzy62's Avatar
schatzy62
HU = Head Unit or Radio
And yeas there is a fuse on the back of it. But it should have blown the fuse panel fuse first, but who knows. Any way it is not a hard job to take the HU out but it can be very time consuming if you have not done it before.
Old Jan 26, 2010 | 08:59 AM
OH REALLY's Avatar
OH REALLY
ya checked that fuse its a 10 and i also checked all the other fuses all are good...
Old Jan 26, 2010 | 10:16 AM
schatzy62's Avatar
schatzy62
The fuse on the back of the HU is a 10 amp Slow Blow but anything is possible.
Let us know what the dealer has to say when it is repaired.
Old Jan 27, 2010 | 05:10 AM
OH REALLY's Avatar
OH REALLY
ok the clock started working but still no radio...
Old Jan 27, 2010 | 05:19 AM
schatzy62's Avatar
schatzy62
Well if you get any kind of display on the speedo display lines then teh fuse on the back of the HU should be good.
But this is actually a good sign.
If I can make the suggestion to remove the fuse in the fuse panel for the radio (HU) and leave it out for 30 minutes and then put it back in to see what happens. This should cause a hard reset of the radio and display system. This may or may not work.
Old Jan 27, 2010 | 05:30 AM
OH REALLY's Avatar
OH REALLY
let me clear that up its the clock on the steering wheel that is working...sorry
Old Jan 27, 2010 | 08:11 AM
strobeyprobey's Avatar
strobeyprobey
So yeah, the fuse on the back of the head unit shown below, (behind the big speedometer) is most likely blown.
Old Jan 27, 2010 | 09:19 AM
OH REALLY's Avatar
OH REALLY
ok i checked that one already so thats not it...
Old Jan 27, 2010 | 10:09 AM
strobeyprobey
Okay, I misread your earlier post. After looking through the WDS here, I find nothing else obvious that you could check. It shows Fuse F21 for the power, and the rest of the troubleshooting steps don't include help for the radio not powering on. You can try this:
Reset CCC
When the rotary pushbutton as well as the buttons CD/MD eject and DVD eject on the front panel are pressed simultaneously, the CCC runs a reset. Run according to the instructions in the test plan.
I really think the HU is now dead and will have to be replaced.
Old Jan 27, 2010 | 11:43 AM
OH REALLY's Avatar
OH REALLY
is the rotary push button number two on the display is that the one i need to hold in and while the car is running or just the key is in ... and how long do i hold it?
Old Jan 27, 2010 | 12:01 PM
strobeyprobey
Good question, and I don't know the answer. Try both of them!
I can't recall now, but there maybe fuses under the hood/bonnet make sure all of those are okay if you have not.
Old Feb 25, 2010 | 04:34 PM
OH REALLY's Avatar
OH REALLY
Well i just dropped my mini off at mini Hendricks and they said they could not put it in writing that best buy ****ed up my radio..lol
you want to hear why....
Because the mini Hendricks team was not there when best buy was working on it....
so i suggest that if you are having any work done to your car always have some one from the dealer with you at all times to make sure your car stays covered under the warranty...ha ha to funny
well i told the lady that best buy knows what they did and they just need it in writing or they will not pay to fix it and then i said i don't understand why you would not want to help me get then to pay for it because other wise its covered under the warranty...so we will see but as of now still no tunes for me..
Old Feb 26, 2010 | 05:40 AM
OH REALLY's Avatar
OH REALLY
well my car goes in at 2:00 and maybe she could sing for me again... You guys have any advice for me?
Old Mar 1, 2010 | 11:35 AM
OH REALLY's Avatar
OH REALLY
well i got an estimate and its 1375.$ for the head unit for my car... they are going with a 2 hour diagnosis and that is 180.$.....best buy is paying for this to get fixed but best of all im getting my car back today...
