Navigation & Audio Swapping audio systems, can it be done
Old Jul 13, 2009 | 12:13 PM
aboss2566's Avatar
aboss2566
I have a friend that works at the mini dealer and he told me that I can swap anything off the trade in and leae returns, so can I swap the audio componants, like bluetooth or maybe hi-fi or nav. with my stock unit. and would i need to swap the wheel to control it.
Old Jul 13, 2009 | 12:31 PM
schatzy62's Avatar
schatzy62
If this is a leased car it must be turned in will all it's original components.
If it is not a leased car then i ti possible MAYBE. it all depends on the wiring harness in the new car some will not take the older components also the programing of the car will be incorrect every time they go to do an update as the VIN number dictates what upgrade are done and if it has componenets that are not listed for the VIN number then those will not be upgraded and that can cause some other problems. Some items can be added others can not.
What exactly is the situation and what parts are you trying to change out?
Old Jul 13, 2009 | 12:36 PM
aboss2566's Avatar
aboss2566
I was hoping to add atleast blue tooth and USB. maybe the HIFI audio if not to hard. But counds like the nave would be almost impossible.
Old Jul 13, 2009 | 03:59 PM
schatzy62's Avatar
schatzy62
if the new car has BLuetooth then changing it to the Bluetooth/USB option is doable but there is at least one wiring harness that would be needed.
If the new car dos not have bluetooth then there needs to be a few (3 i believe) wiring harnesses added or changed.
HiFi takes a completely different main harness than the non HiFi so it means takign the whole car apart. Buy a new car with it already built in. Also the HiFi option IMHO sucks. Read here about how many people dislike it.
Again NAV has a completely different wireing harness in the car. not at all practile to change.
Old Jul 14, 2009 | 05:34 AM
aboss2566's Avatar
aboss2566
thanks for the feed back. but the usb/blue tooth is do-able and the sat radio is too?
Old Jul 14, 2009 | 10:16 AM
schatzy62's Avatar
schatzy62
Yes but the cost is still a factor. I would suggets just finding a car with the options you want rather than spending all kinds of extra money to do something after the fact. it will surely cost you more in the long run to redo the car.
Old Jul 20, 2009 | 10:25 PM
juchong's Avatar
juchong
Also remember that some parts (like the speedo and stereo) are tied to one specific mini, so you might need to take the car in to the dealership to have the new hardware bound to your mini. Also, whenever you install something new (like, for example, if I went in and had satellite radio put into my mini) the dealership would have to re-program my mini with software which supports the new hardware.
If your friend works at the dealership and can do all of this for free, then I don't see a problem with it... if not... well, it can get pretty pricey...
iggi
18
Feb 9, 2026 01:00 AM
khumpert
Nov 30, 2015 11:48 AM
theblackfalcon
Oct 11, 2015 09:49 AM
jeffbeckhudd
Aug 29, 2015 09:11 PM
