Navigation & Audio Is my NAV going out?
Old Mar 22, 2009 | 09:07 AM
DougVarney's Avatar
DougVarney
I've got a 2003 S that is suffering from the display screen for the NAV and computer display not always "displaying". I start the car, screen is black with no Mini logo, no display whatsoever. Then after 5 minutes or so it'll suddenly come on. Anyone know what could be causing this?
Old Mar 22, 2009 | 09:19 AM
lilruffcat's Avatar
lilruffcat
I have not had that issue.. mine is 06 S, but sometimes I do see lines that actually run up the screen, there are like three of them.. I should get it to the dealership to see just what is up with it..
Old Mar 22, 2009 | 09:25 AM
lhoboy's Avatar
lhoboy
Mine did that about 3 years ago. Since it was under warranty, I took it in and they replaced the entire nav box.
Then about 3 months ago, same thing started to happen. But the problem went away after about 3 weeks. Now working fine.
I suspect it is cold temperature related.
Old Mar 22, 2009 | 09:52 AM
rkw's Avatar
rkw
The delay with the screen display may be an indication that your battery is dying. This has been documented several times in the forums and I would look at getting the battery replaced. I have an '06 and at around 3 years/36K miles my Nav started to delay up to about 10 seconds before displaying. I already knew about this from the forums but others had mentioned delays of 20 to 30 seconds, so I thought I didn't have to handle it right away. But within a couple of weeks my battery suddenly died -- car wouldn't start. After jumping, the battery still went dead again within a day. All the problems including the Nav delay went away with a new battery.
Old Mar 22, 2009 | 10:11 AM
DougVarney's Avatar
DougVarney
Thanks, guys! It has been cold, that might be the problem. Also, regarding the battery, I replaced it about a year ago at the dealer. I'll take it back and see if that is the problem, if so they'll replace it, or I will.
Old Mar 22, 2009 | 02:54 PM
lhoboy's Avatar
lhoboy
Since the Nav for the '02-'03 cars were totally different (CD based) than the later Gen1 units (DVD based), you will need to weigh responses accordingly.
Old Mar 22, 2009 | 03:49 PM
rkw's Avatar
rkw
Okay, you've jogged my memory about this. I can't believe my brain is so overflowing with MINI trivia. There was indeed a temperature problem with early Nav units, and apparently a software fix for it. See this thread: http://www.mini2.com/forum/faults-fi...ystem-fix.html
Old Mar 22, 2009 | 04:58 PM
lhoboy's Avatar
lhoboy
Great memory!! 2003!!!
1ZigZag
Oct 6, 2015 07:08 PM
TurboMike
New York/New England
Sep 28, 2015 08:12 PM
The Rossness
Sep 17, 2015 03:06 PM
qwispichkn
Sep 17, 2015 11:28 AM
