Navigation & Audio Connecting Amp to Battery
Old Aug 6, 2008 | 09:37 PM
n_wong89's Avatar
n_wong89
I have seen some pictures on installing wires to the battery from an amp. The only confusion i have is the grounding wire. I know the amp has a ground wire to the chassis/body. Is there a ground wire for anything else?
On the monster cable installation kit, it says there is a ground wire for the battery when you are hooking up your cable.
Sorry i am very new to this, and basically i need to know the full wiring instructions for amp to battery...vice versa.
Old Aug 7, 2008 | 05:25 AM
pentavolvo's Avatar
pentavolvo
positive wire runs from amp to fuse holder to battery
negative wire from amp runs straight to a chassis ground point within 3 feet of amp
Old Aug 7, 2008 | 10:24 AM
ScottRiqui's Avatar
ScottRiqui
You can also ground the amp directly to the negative side of the battery, which can actually be more convenient than using a body ground if you have an MCS and the amplifier is going to be installed in the back near the battery.
Also, put the fuse in the positive amp wire as close to the battery as you possibly can. The reason is, if any part of the amp wire between the battery and the fuse accidentally shorts to ground, the amp wire will burn up. So, keep that unfused length as short as you can.
Old Aug 7, 2008 | 08:09 PM
n_wong89's Avatar
n_wong89
Any tips on hooking the remote wire up? / not letting the amp drain my battery?
Old Aug 7, 2008 | 09:27 PM
ScottRiqui's Avatar
ScottRiqui
If the amp is going in the back of the car, the auxiliary power outlet in the boot is a convenient source of switched +12V power for the amp remote lead.
Old Aug 9, 2008 | 09:07 AM
n_wong89's Avatar
n_wong89
Okay so where would i exactly be connecting the remote wire... like what part of the 12 volt outlet in the boot?
Old Aug 9, 2008 | 09:11 AM
n_wong89's Avatar
n_wong89
Or should i just connect the remote wire to a fuse in the front passenger seat? (if that even works, in the infinity install sub/amp...if anyone read it, they did that).
Old Aug 9, 2008 | 09:14 AM
ScottRiqui's Avatar
ScottRiqui
The 12 volt outlet should have two wires leading to it. Use a meter or a test light to determine which one is at +12V with the ignition on - that will be the wire that you'll tap into for the amplifier remote lead. I don't know the wire colours off the top of my head, but one of the wires will probably be black or brown - that would be the ground wire for the boot outlet. You'll want to use the other wire.
Old Aug 10, 2008 | 08:57 PM
n_wong89's Avatar
n_wong89
Sweet, thanks ScottRiqui! Thats a good idea. Much better and easier then fiddling with the fuse box.
Old Aug 12, 2008 | 10:34 AM
k6rtm's Avatar
k6rtm
WARNING -- CONTAINS POTENTIAL HERESY!
How much power does your sub amp draw? Really draw? What's the fuse rated at? Max current is going to be under what the fuse is rated at.
Look at some AWG wiring tables (google "AWG wiring") and that current level.
Hmmm... The usual tables suggest you should use 8 gauge if you need to supply 60 to 70 AMPS.
My one-piece Boss bass600 10 inch sub with cheezy amplifier has a 15 amp fuse, and draws less than 15 amps peak. Still, wiring it for the fuse, I could use 18 gauge wire. Nah, I'll use 16 or 14. But I'm sure not going to use 8!
And that aux power connector in the boot? That circuit is fused at 20 amps.
Cheers--
Old Aug 12, 2008 | 03:34 PM
n_wong89's Avatar
n_wong89
Well i am new to all of this, but i bought a monster amp install kit for a 500 watt systems and lower. Has an 80amp fuse.
My buddy has given me a 400 watt clarion amp to install. Thats all i know about it...so this is why i bought that monster kit.
Does this sound okay to install. Hooking the remote to the boot 12-volt...and what not?
Old Aug 12, 2008 | 03:42 PM
digi0123's Avatar
digi0123
http://stingerelectronics.com/produc...-1&ParentID=-1
or maybe.....a 90a breaker instead....
also look into the big three upgrade...make sure your power wires all match up gauge-wise....
Filmy
15
Jun 6, 2023 06:27 AM
UncDeo
Nov 4, 2019 04:08 AM
Filmy
Apr 28, 2019 11:37 AM
Filmy
Sep 7, 2015 08:27 PM
jesterofatlas
Sep 4, 2015 11:23 PM
